Question about Sony NWZE345 MP3 Player
When i plug it to laptop it doesnt show up when i goto the my comp. screen.
Posted by spinoffjunki on
Anonymous
    New Friend:
Http://esupport.sony.com/CA/perl/swu-list.pl?mdl=NWZE345&SelectOS=28
just download that and it should register in your computer
Posted on Feb 28, 2011
1helpful
2answers
I recently restored to factory settings on my HP laptop.once restored I then input my Iomega drive into the USB port to access some of my saved files.
Just to be on the safe side, why not plug in your iomega drive into another known working computer and see what happens. If it works fine and is properly recognized then the anomaly lies within the software of your laptop.
U might want to contact HP - but be fore warned that they are terrible for support if your unit is "out of warranty." If that is the case I would simply google the anomaly and in all likelihood you will get links that will help you fix it yourself.
2answers
How do I connect acer aspire to tv
You will need an HDMI cable. Connect the laptop to the television and on the television, you will need to change the "Source Input" setting. Select the HDMI setting on the television and everything that you see on your laptop will appear on the television.
2answers
I have a samsung g2 500gb hard drive.. just bought it but it does not show when i plug it to my dell laptop using windows seven yet it lights showing there is power to the hard drive.....
Hi, you will have to first setup the drive first-goto- control panel----admin tools---comp management----disk management,you will see your drive there, right click and set it up as required, don't forget to format it..
let me know.
1helpful
I have unplugged my maxtor 300gb external hard drive from one pc and have plugged into my laptop to transfer data. Light goes on but doesnt seem to be showing up on laptop 'My Comp'
you might want to try to unplug to HD's power and plug it back in then plu the USB into you computer....make sure that you remove the usb safely and not just unplug it.
250gb external by coolmax, not showing up on comp
The unit (more precisely the hard disk inside it) just died - nothing you can fix unfortunately.
DOES NOT START SHOWS BLACK SCREEN
do a power drain
- shut down the comp, unplug the adaptor and unplug the battery
press and hold the power button without any power connected to the comp
- plug the battery and plug the ac adaptor and turn on the comp
2helpful
Water damage, comp doesnt recognise and screen shows blue
http://www.fixya.com/support/r3771170-phone_water_damage
Orbi cam does not full screen
there may be low resolution in the settings . You have to change some settings to make view of the full screen.
there are two settings to change for get the full screen.
  1. Right Click the My Computer properties
  2. goto the properties
  3. goto the settings
  4. goto advanced settings
  5. In advanced tab goto the trobule shooting in that see the Hardware accelarator.
  6. drag into the high .
now check your the web cam now
if prob comes again please inform to fixya.com
bye
Screen doesn't work properly. Can just see windows loading if hold screen to light. Computer Compaq Presario V2157Ap or V2000 both nos on back of comp
1st test,- connect an outside [test] monitor to the back .There is a VGA plug somewhere back there. If the screen come in good, the problem could be your Laptop monitor screen.
If the connected test monitor acts the same, visually, the problem is in your Laptop.
2nd.test- goto BIOS setup and press F=function that set your laptop to DEFAULT, reboot and see.....
3RD. test- [POWER OFF!!] switch ram chips around from one socket to the other ,, reboot or power on
4th:replace memory chips with KNOWN good ones
If u still have problems, goto technician for help
2answers
Moto rokr e6
please goto the setup menu on the phone and check for the USB mode setting of the phone.It should be as Mass Storage.
Your phone will be recognized as a druve in my comp.
transfer files as you copy ans paste between different folders!!!
if the solution doesnt solve please let me know?
tks and rgds
bm
Sony NWZE345 MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
