Look at the sidewall of one of your tires.
It should have the tire size molded into it.
Take that info, and either look it up online, or go to a tire/wheel shop and ask them what size rim to get.
two bolts...probably 5/8th socket size need to be loosened to almost off the end of the axle. You will have to release the brake either at the brake grip witch could be a quick release that pushes to the side or at the back brake itself by squeezing the brakes in with your hand and removing the cable. Push the wheel forward and down while pulling the derailer out of the way (extend it backward). Once the wheel is out a tire removal kit works the best (if careful two flat blade screwdrivers work) to not damage the rim, tube further or the tire itself. Position one screwdriver in between the tire and the rim, catch the edge of the tire and pry it outside of the rim (they are pliable so don't worry about damaging). Keep the first driver in place and grab onto a second position on the tire and pry it the same way about 8 inches away from the first. Remove the whole tire on one half and remove the tube. Replace or patch the tube and put back together.
Can you explain why you think the tires are too big? Do they NOT fit the rims? What condition was this bike in when you bought it? If the brake pads line up with the rims then the wheels are correctly sized for the frame.
I have some tips I learned from finding a trailer for my 27 foot cruiser. Really, you can find deals in this economy that make rigging a trailer from scratch too much work.
You need to find the loaded weight of your boat and where the hull needs support from Carver. Your trailer needs to hit the "Chines" correctly, meaning the bunks have to be adjustable to the contours of the hull.
The bunk supports can fit outside, inside, or on top the frame rails Mine started on top of the rails and were converted to the torsion axles, requiring new supports.
The axles need to support enough weight and State laws will say how many axles need brakes. Your choice of electric or hydraulic. The bunks should be made of Cypress, but synthetic decking could be cheaper. Your tires should Load rated D or better and 15 to 16 inch wheels, not 14 inch because of the weight.
There are numerous Boat Salvage yards listed online.
There seems to be a "thing" about the region the boats are used. Some places have orphaned trailers everywhere and others are always married to a trailer.
I have seen Boatyard liquidations with ridiculously cheap trailer prices. Use the internet and look.
