Question about Hotpoint Washing Machines
Filling up with water in fabric conditioner dispenser after wash
Posted by jan1807 on
Anonymous
    Sergeant:
  • 196 Answers
Try removing the drawer and cleaning the fabric softner dispenser throughly, remember to remove the level guide for the softner and clean. This works on a siphon system. Hope this helps
Posted on Feb 28, 2011
How-2-Repair.com
  • Hotpoint Master
  • 744 Answers
Hotpoint
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Soap dispenser keeps filling with water after everyload. I have to empty after load. The dispenser is also growing mold.
You should clean the soap dispenser regularly by removing it from the washer.
Some units have a release clip but some just need to be pulled out firmly by hand.
Then give the tray a very good clean as no soap residue should be present. It sounds like the fabric conditioner cycle is filling the relevant tray section but unable to drain through blockage.
Should be pretty straight forward to remedy.
My regards
Marc
Apr 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
Fabric conditioner not taken or not dispensed.
take out the drawer that the powder and conditioner goes in. the conditioner spout to allow the liquid to empty from the drawer will be blocked with a mixture of powder and conditioner. clear it thru with a sharp screwdriver or similar and wash under the tap. replace back in place should empty fine then. hope this helps.
Apr 12, 2009 | Washing Machines
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Washing Machines Logo
133 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
