Question about Kirby Shampooer Shampoo Hose G3 Ultimate Diamond Vacuum
Don,t wast time just click on this link and get step by step instruction from our experts:
http://www.refreshmattress.com/about-us.html
Posted on Sep 13, 2019
There are several guides on internet for mattress cleaning you can easily remove coffee stains blood stains and odor from your mattress with simple steps. I have found a very detailed guide about How to Clean a Mattress https://sleepyfoams.com/how-to-clean-a-mattress/ I hope this will helps you to sort the issue.
Posted on Sep 07, 2019
There is no other way to clean mattress except by using a vacuum cleaner. It is because when you use water in cleaning your mattress, this might start molds especially when the mattress layer has remains of moisture. If you want to have a stain free, spotless and moisture-free mattress, use a mattress pad. Or you may use a waterproof mattress pad to avoid unwanted stains in order to keep a clean mattress at all time. A waterproof mattress also protects your mattress against undesirable odor and has maximum protection ability.
Click the below link to know more.
How to Keep Your Mattress Clean by Moazzem Hossain
Posted on May 16, 2017
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
