Hotpoint WMM65 Front Load Washer Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, my machine is making a noise, when the drum is turning and its leaking water??? the water is brown???
Anonymous
Level 2:
Sergeant:
  • Expert 196 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
196
Questions
0
Helped
69448
Points
647
Your bearings are faulty and the water is leaking out through them. You can get a bearing kit for it but would recommend having a professional fit them as it is a tough and time consuming job, about 2 hours labour. Hope this helps.
3helpful
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Drum is loose moving back & forth, water leaks & water do not drain from drum
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
2answers
Leaking water at the bottom and making load noise
From the description of your problem, there are two possibilities.
One, water valve will have to be replaced.
Second, the area of the leak indicates a leaking drain pump.
Hope this helps.
1helpful
LG Washer makes LOUD noise when spinning
The main seal is leaking on the drum bearing hence the splatter of soap softened grease The water from the drum is coming through the seal and into the bearing and this is washing the bearing clean of grease. No option than to get it replaced with a new drum bearing kit , Sorry !!
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
FAULTY WASHING MACHINE
is it a GE or Hotpoint? if so it is the main bearing. the center seal might have leaked water on the bearing.  if you look inside the washer you will see a ring of rust splatter inside the case of the washer. if this is the case than you have to change the transmission or buy a new machine.
transmissions are $200+
4helpful
SPOTS ON WHITE CLOTHES
if your washer has a slight rumble noise when on the spin then it is most likely that your bearings are on there way out,what it is is the bearings have grease in them and once the bearings start to go this grease starts to leak into the drum which is what the brown spots are it also leaks at the back around the bearing at the back of your outer drum and also leaks onto the floor this will need fixing by a domestic appliance engineer but it is sometimes cheaper to replace the washing machine
2answers
Leaking water from the bottom, checked all connections and no leak from connections. Also making noise when running.
Take front of washer .. get light and look for leak and listen to find out where noise is comeing from
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
