Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
Error E31 on Bushnell V2 - Bushnell Tour V2 Pinseeker Laser Rangefinder
  • townclarke Apr 21, 2011
    Noted your comments with interest however....It was an alkaline battery, same as I always used, but Bushnell would NOT re-program, I have been advised by them that there is no repair available, I will have to purchase a new set of V2's. Disappointing indeed.
  • 17,970 Answers
Can you check that the new battery is an alkaline battery? If it is, and you are still getting the E31 error code, you will need to return your rangefinder to Bushnell to have it reprogrammed.
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. Non-alkaline batteries just don't generate enough current for the laser to operate properly.
Good luck.
Posted on Apr 20, 2011
6ya staff
SOURCE:
I have a bushnell range finder tour v3 and it is reading e31 why and how do I fix it?
I've read some scary reports that e31 might mean you are out of luck.
I'd still get onto Bushnell themselves and ask them what it means.
Be sure to ask them for a quote before agreeing to send it away for repairs. Often when there's a hardware issue inside the device, because of stupidly high service fees, you could be better off just purchasing a new one.
Dec 04, 2017 | Bushnell Optics
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
Dear Sr, I have problem with my Elite 1500 Laser Ranger Finder. Error E31 on Bushnell Elite 1500. Could you show me how to solve this proplem as soon as possible. Thank you and Best...
The e31 error apparently has to do with not using alkaline batteries try replacing the batteries with regular alkaline batteries and trying again.
May 04, 2011 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Tour V2 2nd Distance Digit Missing
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Jan 14, 2010 | Bushnell Tour V2 Pinseeker Laser...
E31 error message on screen of pinseeker 1500 bushnell
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. "lob" means low battery condition. In these rangefinders "lob" will show up with a new non-alkaline battery installed. Non-alkaline batteries just don't generate enough current for the laser to operate properly. Reprogramming costs about 20 bucks, if it needs an alignment (won't hit a flag or target at 200+ yards >50 bucks<) Oily looking spots in the display are from not using the eyepiece cap and direct sunlight damages the LCD. (15bucks) The address for repair is:
Bushnell Repair Center
8500 Marshall Drive
Lenexa, KS 66214
800.423.3537
Send a problem statement, your phone number, and $10 for return shipping.
Good Luck to you!!!!!
Mr Tech Geek
don't forget to vote/rate me....
Jul 03, 2009 | Bushnell Optics
Bushnell Rangefinder Tour v2 E31 appears in viewfinder
If it is 2 years or less from the date of purchase.....send a copy of the POP (proof of purchase) or call them......! It should be under warranty. This is the real deal!!!
rate if you can!!
MTG
Jun 12, 2009 | Bushnell Optics
Bushnell rangefinder laser 400 golf shows an E 6 at the bottom and thats it. How to fix? its a 97 only used for golf worked fine put new battery in this year and I got the E-6 error
E6 means the unit has cpu or program failure....The only thing that bushnell can do is replace your unit with a newer one Its over 10 years old..... They won't have any parts or able to reprogram it.(they just do keep parts that long) They will offer you a model 20-1916 ($151.00 bill) (you can it see it @ bushnell .com.) The better model is........if you play golf is the Medelist(20-1354) or the Tour V2(20-1930).....The top of the line is the Pinseeker 1600(20-5105 without the slope function) or the Pinseeker 1600(20-5106 with the slope function).......If you hunt I would go with the model (20-1932 with the ARC fuction..... This is the real deal....call them
mtg
Apr 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
Just a question
no i have found the actual flag is pretty accurate as long as its not black- the reflectors increase accuracy over distance
Dec 24, 2008 | Bushnell Tour V2 Pinseeker Laser...
Just a question............my understanding is that a Bushnell V2 Rangefinder does not require reflectors on the pins.........is that correct?
not required- in does increase measuring distance past 300 but w pinseeker and most approach shots from 250 in -plain flag is plenty
Bushnell Tour V2..no display
If the unit gets hot (like in the trunk of a car), the LCD display will go out. Keep it in the house and it should get better when it cools.
Oct 05, 2008 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
2,984 people viewed this question
Top Bushnell Optics Experts
Ekse
Marvin
Marvin
lectricjohn
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
