Hifonics Generation XI Thor Car Audio Amplifier Logo
Question about Hifonics Generation XI Thor Car Audio Amplifier
Im looking for a company that sales hifonics samson xi line input that broke of my amp..
Posted by jdmouteg on
Anonymous
    Novelist:
  • 147 Answers
Hifonics is sold by Maxxsonics
http://www.maxxsonics.com/hifonics/
You can contact them at [email protected]
Posted on Mar 04, 2011
How to connect a samson s mix 5 channel mixer
It depends on what you are trying to connect. The XLR would be a professional type microphone, it does not have phantom so a condenser mic will not work. The other inputs should match your stereo equipment. The output goes to your amp.
The Samson S-Mix is a miniature, rugged 5-channel audio mixer with 4-line inputs and a single XLR microphone input. The line inputs are comprised of two 1/4" phone and stereo RCA phono connections. Each input channel has a rotary volume control and the outputs include stereo RCA phono connectors and 1/4" TRS phone headphone output. The S-Mix is powered with an 18 volt AC adapter.
Getting distorted sound when connecting from mac pc headphone jack to 1/4" line in input
You are connecting a NOISY unbalnced line to a balanced input. Buy a DI box and then use an XLR to XLR to the mixer inout and run the MAC into the DI with "ground lifted". You will need to make a resistive mixer between the headphone jack and the DI as well. The headphone jack is STEREO. You COULD try a STEREO 1/8 inch splitter to 1/4 inch left and right cable... you MIGHT get away with that. Right now the left and right amps in the MAC are fighting eachother.
Where can I find repair service in cleveland area to sharp the saw chain
Dex Online – saw/chainsaw
Chain Saw Sales Inc
386 Broadway Ave, Bedford, OH, 44146
Distance: 10. miles
Egy's Mower & Chain Saw Service
545 Hall Rd, Elyria, OH, 44035
Distance: 24. miles
Stihl dealer locater
Greenes Hardware & Industrial Supply
Full-line Sales & Service Dealer
7734 Broadway Avenue
Cleveland, OH 44105
* * Sill's Motor Sales Company
1901 Brookpark Road
Cleveland, OH 44109
* * Lanphear Supply
* Lanphear Supply
1884 South Green Road
S Euclid, OH 44121
* * Chain Saw Sales
* Chain Saw Sales
386 Broadway Avenue
Bedford, OH 44146
* * North Royalton Power Equipment Co.
10156 Royalton Road
N Royalton, OH 44133
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
I hook it up and the diag light comes on
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
I hook the hifonic amp up and it cuts on but the subs dont beat but the subs work
Try switching around one of the pos/neg speaker wires (you may have one crossed and they are firing out of phase, meaning when one pushes out the other pushes in and vise versa causing the base signals to cancel each other out) while the system is playing, only switch one speaker,not both. You can normally look at the subs and tell if they are moving very good and not much bass is there, you could also have the wrong box for them, this will also give a similar result
CLIPPING ON ONE CHANNEL HIFONIC FALCON
clipping can result from improper wiring or solder jumps to figure this out youll need a continuity tester simply check you inputs and outputs and make sure wiring is correct then if so your amp has a solder jump inside them amp. New amp or send it in for repair you can buy a new amp nearly every brand at dealer cost from this site.
www.godspeedaudioheaven.com
2answers
Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Problem!
you have a foulty amp i wtake it bk and change it
Overheating
The Kicker 10 may be running a 1 ohm load and that amp isn't 1 ohm stable.
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
