Question about Whirlpool MH1140XM Microwave Oven
How to set a time on a whirlpool microwave X2=40ES
Posted by gillharwant on
Have a Whirlpool over-stove microwave. Can set time but then it scrolls between AM & PM. Cannot find how to set the AM/PM portion, and completing the time set.
Which microwave model do you have? Most of the Whirlpool microwaves that I know only have a 12-hour clock. They do not indicate AM or PM. To set the ones that I know, press Clock. Type in the current time in a 12-hour format. Press Clock again. The only model that I find quickly that has an AM/PM option is the GH7208XR. On that model, start with the main menu displayed on the LCD screen. Touch Settings and Info. Next press Clock. Then press Adjust Time. Follow the instructions to set the time and the AM/PM setting. I'll assume you use the +/- buttons. To hide the clock, get to the Clock Screen. Press Adjust Time and Hide Clock to return to the main menu. See these two pages of the manual for this model: https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=9#manual and https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=12#manual
Current Whirlpool over-the-range models sold in the US are listed here: https://www.whirlpool.com/kitchen/cooking/microwaves/over-the-range.html . Other Whirlpool appliance manuals are available from the Owner Support page: https://www.whirlpool.com/services/manuals.html.
I hope this helps. Please add a comment with the model number for a more accurate information on setting the clock. The model number should be inside the microwave on the rim. Usually it's on the bottom of the door frame near the door hinge.
Sep 19, 2018 | Whirlpool Microwave Ovens
How do I turn on the microwave and set the clock
PDF]set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../set-up_guide_en_o...
PanasonicPress "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
[PDF]MICROWAVE OVEN - Whirlpool
www.whirlpool.com/digitalassets/.../Use%20...
Whirlpool Home AppliancesIf materials inside the oven ignite, keep oven door closed, turn .... This is a standard 12-hour clock (12:00-11:59). To Set: The microwave oven must be off. 1.
[PDF]BUILT-IN MICROWAVE OVEN - KitchenAid
www.kitchenaid.com/digitalassets/.../Use%20and%20Care_E...
KitchenAidSee "Clock" section. The microwave oven will also turn off when the door is opened.... Use the dial to select options, set the clock, set cook time and cook power ...
[PDF]
Jan 14, 2016 | Microwave Ovens
Whirlpool microwave
    • 1 Press the "Clock Set/Start" or "Clock" button on the control panel.
    • 2 Enter the time of day using the number pad, or use the "+" and "-" buttons to scroll to the correct time.
    • 3 Press the "Clock Set/Start" or "Clock" button once again to save the time.
Apr 11, 2012 | Microwave Ovens
Hi we have a Whirlpool X2-20ES microwave oven How can I set the clock (day time)? Thanking in advance Sid
1. Press CLOCK
2. Press STOP
3. Press number keys with correct time (123 = 1:23)
4. Press CLOCK again
Jan 28, 2011 | Whirlpool Microwave Ovens
Whirlpool Roper Microwave MHE14XMB turntable stops turning
Hello :
The turntable has a separate motor under the unit(inside) that is quite small..... They just do go out from time to time..!!!!! Just remember to set the timer for shorter periods of time on items that require long cook times and turn it around the other way . Repairing is a bit expensive . You can ask first .
good luck .
please rate .
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
Wont work
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Oct 20, 2009 | Whirlpool Microwave Ovens
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
Jul 03, 2009 | Whirlpool GH4155XP Microwave Oven
Whirlpool MH1140XM Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
