Question about iRiver H10 MP3 Player
My Iriver froze so I tried to reset it through the reset button.. but the screen displayed this message.. Emergency USB. What should I do?
Posted by jnrtupou_waq on
Anonymous
    Problem Solver:
  • 11 Answers
Morning,
May I ask about your computer Operating System? What is it please. ALso, how long have you had your iRiver and had it ever functioned properly?
Posted on Feb 28, 2011
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3answers
Emergency usb mode
Have you tried connecting the usb and loading an update on it at all?
Let me know if you have or if trying that doesn't work and if it doesn't then I will provide further help based on the situation
Thank you for using Fixya and Good Luck
2answers
Iriver Clix USB freeze
My screen also froze in the music menu, but when I connected to the PC, it was recognised and I could get into the files. Try resetting it by sticking a paper clip in the reset hole if you've not done it already. Mine's working fine so far....
6 gb version of H10 displaying error message on start up
you need to upgrade firmware to version 2.51 using the mtp upgrader download found at www.iriver.com-support-ask.asp after doing this your player should work this upgrade is a recovery tool and works very well with all mtp version players
4answers
REPAIR OF IRIVER H10 20G
Try rebooting the little hole next to the lock with a pen or something similar mine works everytime
E10 Problem
You need to upgrade the firmware by using iriver plus 3 in the 'tools' section it should have upgrade firmware.
4helpful
7answers
E10 "Emergency USB" fault
I have had the same problem many times and would like to see an update tothe firmware to fix it. Here is what I did. Rurn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a staple. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit turned off.
I hope this helps.
4helpful
IRiver E10 - Error screen - Emergency USB
Hi There,
There are 2 conditions related to the e10 Emergency USB message.
1. If your PC does NOT recognise the iriver as a USB device/drive, there is an issue with the Hard Drive.
2. If your PC DOES recognise the iriver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
In either case, your iriver needs to be returned to the manufacturer. If in warranty you can get this repaired at no cost (of course).
IRiver H10 20 GB
Hi Vera I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB >using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer easyh10-15.exe Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10 URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796 download 'easyh10-1.5_win32gui.zip' - connect USB cable between Pc and H10 - place H10 in 'Lock' position - use a tool ( refashioned paper clip ) to press the reset button - start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button while you press the 'On / Off ' button until screen displays USB connection, after emergency display - In Windows Explorer locate the ' removable drive' - Transfer your music files with tag information to 'Music' directory on H10 - Run EasyH10 - for Media database construction to display songs in MUSIC mode. - Playlist conversion, a necessary process for your playlist files to become compatible (recognizable) with an H10 player. - EasyH10 also imports/exports tuner presets from/to a text file. Prh
IRiver MP3 Player Not Inisializing
If you haven't already I would try an emergency connect. -First perform a standard reset as you did before (press rear button for 20GB or disconnect & reconnect the battery for the 5/6GB versions). -Leave the unit turned off, but connect it to your computer's USB port. -Hold down the "o" button and then press the power button for a second to power on the device. -Do not release the "o" button until you see a message such as "emergency connect" or "mass storage" on the player screen. I beleive the message has changed with firmware versions, but it should be something similar. -If this works it should be detected by your computer as an external drive. You should have access to the files. -I would remove all music files from the device and then use the iriver plus software to restore system files. -If you manage to get to this point I would install the newest firmware available for your model of H10, found at the iriver site. The newest firmware adds a lot of functionality, speeds up player response significantly, and fixes many bugs as well.
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Jean Sintulaire
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
