Question about LGDVT418 System
Rear speakers wont work when watching tv but works when watching a dvd
Posted by stack3329 on
Anonymous
    New Friend:
  • 16 Answers
You need to set your tv to 5.1 digital surround sound, then it should work.
Posted on Feb 28, 2011
Right speaker doesn't work
Does this happen when watching TV or DVD?
Is your TV connected to a cable box?
Are using AV 1,2 or which source?
Make sure audio cables are inserted all the way.
Audio balance on TV has to be in the middle for both speakers to work.
N Sabre
Nov 07, 2009 | Zenith R40W46 40" Rear Projection...
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
Center and rear speakers not working
In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
Jun 26, 2009 | Audio Players & Recorders
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Speakers work only on DVD
You might have connected your TV/Stereo Receiver up to the wrong audio outputs of the DVD player. Make sure you are coming out of the FRONT left/right audio outputs and not the CENTER?REAR left/right audio outputs.
Mar 13, 2009 | Panasonic SB-TP55 System
LGDVT418 System Logo
Top LG Audio Players & Recorders Experts
tina gallow
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
