Most likely problem is a failed condenser fan motor. pull your refrig away from the wall and then remove rear cardboard cover. you will see a fan motor that cools the compressor and condenser coils. heck to see if the fan is jammed with insulation or other objects. if the motor needs to be replaced you can place a portable house fan blowing int the rear to keep components cool until unit is repaired. thanks peyton
