SOURCE: Kitchen Aid food processor, model # KFP 700 from 1970s
The closest I have seen recently - there is an auction for a complete KFP-700 with work bowl/lid intact on eBay right now:
http://cgi.ebay.com/Kitchen-Aid-12-Cup-Food-Processor-model-KFP-700_W0QQitemZ150328616612QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US
-Tha Mp3 Doctor
SOURCE: I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
SOURCE: I have a Kitchen Aid KPF700 Food Processor and
The unit has been retired, but Kitchenaid may still parts available. I would recommend to call Kitchenaid Customer Service and speak with their parts department. Their toll-free telephone number is:
1.800.541.6390.
SOURCE: My 12 cup kitchen aid food processor dough blade
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
SOURCE: I need a copy of
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual or the model number of your food processor is different from the one in the manual.
Thanks for using FixYa.
