Question about Visonik Car Audio & Video
I want to now if the visonik vb210 car amp is 2 ohm stable or what the most lowest ohm load for it is
Posted by boss305h on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: solobaric subs l7 15-inch
when you drop the Ohms and put them together, they go even lower. 2ohm + 2ohm = 1ohm which ur amp is not capable of. try this, with one subwoofer on one voice coil connect the positive (+) and negative(-) together(the ones without the dots) and the ones with the dots run to the speaker terminal like normal. do this for both speakers
<a href="http://s14.photobucket.com/albums/a312/kimsam/?action=view&current=2_4ohmDVC_1ohm.jpg" target="_blank"><img src="http://i14.photobucket.com/albums/a312/kimsam/2_4ohmDVC_1ohm.jpg" border="0" alt="Photobucket"></a>
this is what you did...
<a href="http://s14.photobucket.com/albums/a312/kimsam/?action=view&current=1_4ohmDVC_8ohm.jpg" target="_blank"><img src="http://i14.photobucket.com/albums/a312/kimsam/1_4ohmDVC_8ohm.jpg" border="0" alt="Photobucket"></a>
this is what you want...
Posted on Feb 12, 2008
brandon day
  • 173 Answers
SOURCE: L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Posted on Sep 14, 2008
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: 2 channel amp with 2 Kicker Cvrs 15"
Assuming the amplifier is 2 ohm mono stable... the amplifier is bridgeable... and the subwoofers are Single 4 Ohm Voicecoils, You would wire them as follows....
Both + on Both subs to the + bridged terminal on the amplifier.
Both - on Both subs to the - bridged terminal on the amplifier.
This will net a 2 ohm mono load for your amplifier.
If you have something different - let me know... and I will give you the proper wiring for what you have.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 10, 2009
Anonymous
  • 12 Answers
SOURCE: i want to know the best subwoofer wiring diagram
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Posted on Nov 30, 2009
Anonymous
  • 41 Answers
SOURCE: how can i wire the dual 1.4 ohm either to a 2ohm
more than likely it will overheat at .5 ohm
Posted on Feb 06, 2010
I was wondering what wattage amp I should have for my 2 kenwood excelon 1600 watt rms 12s an if I should wire them parallel
first thing are the subs 1600rms a piece? If so, buddy you need about 3000 watts rms. No less than 2000 to do them justice. Wiring parallel depends on the ohm load of the subs, if they are dvc's and the lowest ohm load the amp can handle. Not all amps are 1ohm stable.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Dec 24, 2014 | Car Audio & Video
How should i hook up a visonik class D vxd709 to my dual voice coil 12" Treo subwoofer?
if your amp is a monoblock 2 ohm stable amp wire the coils positive to positive and negative to negative into a single channel that will create a 2 ohm load turn your amp down and adjust by ear till it sounds good if your amp is a 2 channel amp 4 ohm per channel wire each coil one per channel turn amp down and adjust by ear till sounds good hope i was helpful
Feb 17, 2013 | Car Audio & Video
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Can you run two mtx 6500d amps in parallel for more power?
Not suggested to parallel the output of two amps. Instead take each amp, find out what the amps lowest impedance it can drive is and select your speakers based on that. According to MTX these are stable down to 2 ohms without a rated output power of 500Watts X 1. If you get two dual voice coil subwoofers with each coils characteristic impedance of 4 ohms, when you parallel the two coils you will get a 2 ohm load. Just maek sure the speaker can handle the 500 watts.
Jan 27, 2010 | MTX Thunder 6500D Car Audio Amplifier
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
Visonik V12D4
i would wire the coils of each sub in series which would yield an 8 ohm resistive load per sub - and then wire the subs in parallel to the amp which would bring the resistance back to 4 ohms for a bridged load which will give you max power handling from the subs and draw the full power of the amp at the same time
Jun 18, 2009 | Earthquake Sound PH800W.2 Car Audio...
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
How to connect a 2 ohm stable in stereo
ok when getting into wiring and impeadances on car audio one must be careful the wrong impeadance with the wrong amp causes overdriving and it will kill your equipment. check the user manual to see if the amp is 2 ohm stable if it is dictated as stable @ 2 ohm there are multiple ways of wiring the speakers to get the load you want i highly recommend 12volt.com
Feb 18, 2009 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
