Question about Vacuums
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first) After programing the TV Mode on the new universal remote sucessfully I tried to program the DVD Mode on the new universal remote. After that all our 83 cable- channels are mixed up in their numbers. The numbers only show up to 69 and not to 82 like before. Channels 7-17 show only weak and snowy reception others are black snowy. Only channels 19-27-29-30-31-32 have a normal reception. This applies to both remotes. Can I reset my Toshiba 27A43 to the Factory mode and and start "New" again?
Posted by rosemarie_ni on
Marvin
    Top Expert:
  • Vacuums Master
  • 85,239 Answers
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Posted on Mar 28, 2017
2 Related Answers
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: i lost the remote and
MAy I ask what you need the new remote for. Once I have this info I will be able to help you program it.
Posted on Feb 13, 2011
shakei16
SOURCE: My tv Sankey remote control
my sankey television is locked what code can i used to get it unlocked
Posted on Sep 07, 2011
Changing frequency on a remotely operated Hampton Bay Celing fan
Remove battery from remote and you should see 4 small switches. Write down the pattern they are in now. Then move them to a new pattern. Then take the bezel off of the fan (where the fan connects to the ceiling). Turn the bezel counterclockwise if you don't see any screws holding it on. Now look for a set of switches that look the same as the switches in the remote. Write down their current pattern. Now Set the switches to a similar pattern as you set on the remote. If the remote doesn't work after adjusting, set them back to original positions from the notes you kept. Good luck
Jul 18, 2011 | Vacuums
I have a rca universial remote control and I lost the manual and cant program it for my toshiba television I need the code and directions how to program it
Not knowing the code, you'll have to do it using the Automatic Code Search method.
1. Turn the TV ON manually.
2. Press and release the TV button on your remote. The illuminated ON-OFF button will turn on and stay on.
3. Press and hold both the TV and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
4. Release both buttons after the ON-OFF button turns back on. The button should remain on.
5. Press and release the PLAY button. You may have to do it several times. Be patient.
If the TV does not respond after five seconds, continue to press and release the PLAY button every five seconds until the TV turns off.
6. Just to check the code is right, after the TV turns off, press and release the REVERSE button then wait to see if the TV turns on again.
If that works, you've got it!
Press and release the STOP button to save the new code.
May 24, 2011 | Vacuums
Need codes for my rca remote, model rcu404n to operate my sony tuner
Go to a computer store and buy a universal remote, they are quite reasonable now, and use that instead.
Apr 25, 2011 | Vacuums
Cant get my rca remote to work on ,my sharp tv i need the code for sharp tv the model onmy remote is rcr311w
Not really sure what to do here, whether or not its a universal remote you are referring to. The attached is a link for almost any users manual for anything electronic. Hope it will help you find the users manual with the correct code. http://www.retrevo.com/support/HP-m8150-Desktops-manual/id/3167ag902/t/2/
Mar 21, 2011 | Vacuums
I lost my codes for my universal remote i need answers asap!
Hi Coourtneeylyn,
You can find the code sheets for the GE Remotes made by JASCO Products at the following website:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Please let me know if you should have any further questions!
Blessings,
GeekyGuru
Jan 03, 2011 | Vacuums
I HAVE A PANASONIC TV W/ A PHILIPS UNIVERSAL SRC306/27 REMOTE. I NEED THE CODES FOR THE REMOTE.
I suggest you check with the manufacturer for that particular remote. If they are available they will be the only place you can find those codes. Or find the book that came with the remote
Mar 29, 2010 | Vacuums
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
