Question about Singer CE-100 Futura Computerized Sewing Machine
I have a futura ce150 and the feed dog is raised but not moving the fabric
Posted by theresawadde on
Beth Millar
    Novelist:
  • 233 Answers
Try lowering the feed dog and then raising it again, but be sure to push the switch over as far as possible. Sometimes the switch will stop just a little short and the feed dog will not be 100% raised but it will seem to be to the naked eye. Hope this helps.
Posted on Apr 03, 2011
I have a brother ls 2020 and it will not feed fabric through. I am thinking my feed dogs are messed up but i don't see anything about lowering or raising them. Will I have to take it apart?
According to the manual, your machine does not have the capability to drop/raise the feed dogs. Instead, there is a cover plate that is installed over the feed dogs when performing darning or free motion quilting.
Check that your stitch length is set high enough to actually move the fabric. Some machines also have a presser foot pressure adjustment that will increase or decrease the amount of pressure the presser foot applies to the fabric and the feed dogs. If your machine has this adjustment, it may help to increase the pressure so the fabric will move better. Another thing to check is whether you are using the correct presser foot that will actually rest on the feed dogs.
Reading the hints on pages 28 and 29 may be helpful.
User Guide Manuals LS 2020 Others Brother
Another possibility is that the feed dog points have been worn off. When the points are worn, they no longer grip the fabric like when new. When stitching, be sure to never run the machine with the presser foot setting directly on the feed dogs, it without fabric.
Jan 05, 2018 | Brother Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
The needle moves up and down and the presser foot is lowered (and attached properly) but the fabric is not being pulled through.
Yes, there definitely could be something wrong, but there are some things you should check. Most machines are capable of raising and lowering the feed dogs; yours might be fully or partially lowered, so that while it moves, it's not far enough up to the surface to move the fabric. Using the lever or dial, LOWER it all the way, then RAISE it all the way, but you're not finished. It will still not raise until you turn the hand wheel TOWARDS you (ALWAYS towards you on every machine) at least one and possibly two revolutions. You'll then SEE and most likely HEAR it click up. I know someone who got a steal on a Brother marked defective because the feed dogs wouldn't raise, so she brought it home, turned the hand wheel two revolutions, and viola! The feed dogs raised!
Dec 03, 2013 | Singer 5050 Mechanical Sewing Machine
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
My feed dogs are raised but the machine will not feed the fabric fast enough even set at 5
Obvious things first:
is the pressure foot lowered to hold the fabric down?
Are the feed dogs clean and not blocked up with lint?
What stitch length have you set the machine to (if this is what you mean by "5" then that's not it obviously)
Is the machine in a buttonholing sequence or something similar?
Are the feed dogs moving at all in the stitching sequence? Raise the pressure foot and without fabric or thread manually turn the flywheel towards you and watch them moving. Are they coming up above the surface of the needle plate during their sequence.
If they are not moving at all, good chance a gear in the lower shaft has failed.
If they are moving but not coming up above the needle plate enough to move the fabric backwards, then they need adjusting to the correct level.
Sep 03, 2011 | Sewing Machines
My fabric wasn't moving so I lowered the feed dogs and now I cannot raise them. The button in the back of the machine moves both ways but the feed dogs are not moving. They are staying in the down...
Hello
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
Jul 12, 2011 | Janome 4623 Mechanical Sewing Machine
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Fabric Won't Move
I don't have this machine, but any machine I've had that you can lower or raise the feed dogs had the switch in the bobbin area. Mine is on the right side when you flip down the little door. It moves up and down to move the feed dogs. good luck
Dec 29, 2008 | Euro-Pro Shark 60 - 384
Singer CE-100 Futura Computerized Sewing Machine Logo
248 people viewed this question
Top Singer Sewing Machines Experts
tsalagi152
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
