The pilot orifice and the Oxygen Depletion Sensor (ODS) need to be cleaned. You can accomplish this by using canned compressed air with a straw nozzle (like you clean your computer with).
Turn off the gas, allow the heater to cool and dismantle the front half potion of the heater. There are 6 to 8 sheet metal screws that hold the 2 halves together. You'll probably find a lot of dust & lint inside the heater. This will need to be cleaned out with a vacuum that has a hose and crevice tool attachment.
Once you have accomplished that, turn your attention to the pilot assembly. Using the canned compressed air withe straw nozzle, blow out the pilot tip with a qucik shot of air. Now, look down the pilot from the tip and about 2/3rds of the way down, you'll see a hole in the side of the pilot. That's the ODS sensor. Stick the straw nozzle just barely into this hole and give it a quick shot of air. You'll probably see debris fly out the other side.
Before you reassemble the heater, turn the gas back ON and light the pilot, but do not light the burner(s). Is the pilot lighting and holding. Is the pilot flame straight or is curling up? If it's curling up, turn the heater off and repeat the pilot cleaning procedure. If it's straight out, reassemble the cabinet and your ready to go.
Now, take a moment and pat yourself on the back. You just completed what's called "Annual Maintenance", which should be done at least once a year, usually in the Fall, before lighting the heater for the season.
Hope this helped you solve your gas heater problem. Please let me know.
