Actually i use pen drive.
karan chanana - karan
Retrieving a forgotten password on a Cruzer Enterprise drive
How do I recover the password on my Cruzer Enterprise drive?
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password, you can click Forgot Password on the logon window and choose a new password. This will reformat the drive.
Reformatting will delete all files and applications in the user-accessible removable partition.
Password attempts
There is a limit of 10 attempts (default) before the drive is locked and no further access is possible. During this process, you MUST change the password and reformat the drive. This is an important security feature, protecting data in lost devices from brute force hacking attempts.
Cruzer Enterprise drive managed by CMC (Central Management and Control)
A drive managed by the Cruzer Enterprise CMC software can be unlocked remotely by the System Administrator when it is inserted into an online computer. The System Administrator can unlock the drive remotely even after the maximum failed password attempts has been reached. The user must then choose a new password. Data stored in the removable partition will be preserved.
If the device is managed but in an offline computer, the System Administrator can send the user a one-time unlock code. The user must enter the code then choose a new password. The existing data on the removable partition will be preserved.
hope this helps
Firstly, use password prompt function on password locked computer
If you have set the prompt option when you set account password, it
may help you remember something about your forgotten computer password!
Secondly, reset computer password with default administrator account
Once we install Windows OS, there will be automatically generated an
"Administrator" account with blank password. Therefore, if we forgot
password on computer, we can have a try:
a. Boot system, and press Ctrl + Alt + Del keys twice when the Windows login screen comes up.
b. At the Classic Login window, input: Administrator and keep Password box null. Then press Enter key to login.
c. Recover computer password by: Control Panel - User Accounts.
Thirdly, find computer password with computer password reset disk
If we created this computer password reset disk before we forgot
password, we can opt for the disk to help us unlock password
efficiently.
a. Click OK and close the message box on the password incorrect prompt window.
b. Click "Reset Windows Password" and insert the password reset disk.
c. Do as the "Password Reset Wizard" to create a new password.
Fourthly, change computer password with Windows Installation Disc
Take computer Windows XP as example:
a. Start computer using Windows XP Setup CD.
b. When it asks to repair our current Windows installation, choose
"Accept" it and press "R" to run the repair. Then computer will begin
to repair our Windows and copy files to hard drive.
c. Setup will reboot system. Please don't press any key when there is "Press any key to continue..."
d. Now computer will do other tasks and there will be a progress bar
displayed. Please notice carefully the details shown at the bottom of
screen.
e. Once "Installing Devices" comes up, press keys: Shift+F10. Input:
nusrmgr.cpl and press Enter key at the Command Prompt window.
f. The same "User Accounts" window will display as it is in Control
Panel. Choose "Administrator account" and select any account listed to
change or remove your computer password.
Fifth, break computer password by DIY a password recovery disk
If the above four methods still can't help us reset lost computer
password, we can refer to this way now. DIY a password reset disk after
forgotten computer password means that we burn an .iso image file from
Windows password recovery software into a bootable CD/DVD/USB disk.
Now, take one of the top-rated Ainorsoft Windows Password Recovery
Corporation as example:
a. Download and install Ainorsoft Windows Password Recovery Corporation in any accessible computer (not from computer you want to unlock)
b. Burn an ISO image file to CD/DVD/USB Flash Drive
c. Set locked computer to boot from CD/DVD/USB Flash Drive and set the BIOS Setting for CD/DVD/USB Flash Drive.
d. Reset forgotten computer password to default Re123456.
The above ways on forgotten computer password reset are the collections of best bet for us to unlock lost computer password! So even if we forgot computer password, things will be OK soon!
source: http://www.windowspasswordrecovery.net/article/forgot-computer-password.html
