Question about Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point
Cant access belkin router w 191.168.2.1 or any combination
Posted by jrvoyage on
Computer hardware and networking support
  • 4,281 Answers
. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Feb 27, 2011
I cant connect to 192.168.0.234??
First reset your router to factory defaults.
You can reset it with RESET button press it for 10 secondsd it is in back side of router.
Then connect your router to comuter with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
for belkin router
http://192.168.15.1
user name as "admin" and if it want password then "admin" or blank or "password"
Then you can access it's configuration.
Feb 19, 2011 | Belkin (F5D7230-4) Router (587009)
On belkin surf router clicked on set as access point. then i tried to change it but my computer cant get internet from the router so i cant access the belkin homepage. can u help
the only thing you need to do is reset your router to go the IP address original 192.168.2.1
because when you setup it as a access point the router change the Ip Address.
restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on theback of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
do this for 3 times and you will acces your router.
Good luck
Please rate me techbelkin
Aug 02, 2010 | Belkin Wireless Surf Router (F7D2301)
Cant gain access to change settings on my router Belkin N1+
hardwire any computer to one of the wired ports in the router...
type 192.168.2.1 in any web browser and log in to router setup utility manually....
password....leave it blank and click submit..
now you can configure settings manually....
Apr 20, 2010 | Belkin N1 Vision Wireless Router
I just reset a belkin g mimo router I cant conect
connect your laptop to your router via patch cord to be able to access the router configuration, then configure it, change the wep keys..etc
hope this thing help
Jan 10, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get router to access internet
The easiest way to set up this router is to connect it via ethernet cable and then access the router with the default ip address and configure it from there
Dec 08, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router
you need to access router configuration page and have it get an IP from Comcast DHCP server.
Jul 01, 2008 | Belkin (F5D7231UK4) Wireless Router
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Belkin router dont take ip
if your in vista, click on the network tab on the start menu, then it should show all of the devices connected to your network, if you see your router, left click it, there should be an option to view device webpage.
Mar 28, 2008 | Belkin (F5D7231-4) Wireless Router
My belkin router wont work :(
If you access your router, look at the wireless settings, you may need to change a setting to allow b + g connections, your laptop may have a 'b' adapter.
Mar 09, 2008 | Belkin (F5D72304F5D7000) Router
Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point Logo
1,175 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
