ViewSonic PJ503D DLP Projector Logo
Posted on Feb 27, 2011
What cable or adapter do I need to connect my projector to a MacBook video out port?
Greg Niblett
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 28, 2011
Greg Niblett
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
3185
Points
10
You will need a Mini-DVI to VGA adapter. Apple sells this item through their online store.
http://store.apple.com/us/product/M9320G/A?mco=MTY3ODQ5OTY
You will also need a male to male VGA cable to attach the adapter to the projector.
You can find modestly priced cables at monoprice or other retailers. example: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10201&cs_id=1020102&p_id=2898&seq=1&format=2
Plug the cable into your projector and then plug the adapter into your MacBook. The MacBook will automatically resize your picture to the appropriate resolution for the projector.
Enjoy!
1helpful
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details:
4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions.
Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work.
No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector.
Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others.
You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
I am trying to connect my apple macbook to a dell projector.
you'll need the appropriate adapter from the video out on your macbook to whatever input on your projector.
For instance, I use a mini-dvi to VGA adapter and VGA cable into my projector.
2answers
What type of cable do I need to connect my macBook Pro to a Dell DLP MP1200?
You should be able to use a USB - 4 pin mini-DIN cable with this projector.
How can i connect the macbook pro into an lcd projector, which adapter should i use....?
what are your options on the projector side?
Your Mac comes with a DVI (Digital Visual Interface) port.
Attach the DVI to VGA adapter to the VGA connector of the external monitor.
depending on the external monitor/projector, you may need different adapters.
What cable(s) do I need to connect a dell 3300mp projector to my Macbook Pro?
HI.... ........YO U NEED A ADAPTER WHICH IS CALLED MINI-DIV TO VGA ADAPTER....THIS ADAPTER WILL HAVE TWO PORTS ONE PORT IS CALLED MINI-DIV PORT ANOTHER PORT IS CALLED VGA FEMALE PORT (WIDER THAN DIV PORT)..NOW PLUG THIS DIV PORT TO YOUR MACBOOK AND THE OTHER ONE IN YOUR PROJECTOR ...YOU MAY ALSO NEED A VGA CABLE..
2helpful
2answers
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
http://www.radioshack.com/product/index.jsp?productId=3898890&CAWELAID=447271885
http://store.apple.com/us/product/MB572Z/A
http://store.apple.com/us/product/MB570Z/A
2helpful
Problem hooking my macbook to the Powerlite 62c/82c the projector
For these types of projectors if you're planning to hook it up using you MacBook ;
You will need a converter ( from VGA to DVI )
Using the VGA cable that came with the unit when purchased ;
Connect the VGA cable on the back of the Projector and on the other of the cable you will connect the converter ( VGA TO DVI ) since for MAC systems it has DVI ports for monitors not VGA...
You can purchase the converter at any Mac store or any computer shop near you..
4helpful
2answers
Apple Macbook pro video out to VGA port ("d-sub") on Optoma
There's no solution. it will not connect with macbook pro or any other mac. as on the phone with all technicians and they do not know what to do. I had the unit replaced and still would not connect.
Top ViewSonic Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
