Question about Music
My westfield e4000 les paul when plugged into anything doesnt work unless its switched to my bridge pickup and turned to 8 volume or lower
Posted by rudeboyhf on
Andrew Conroy
    Sergeant:
  • 298 Answers
Chances are that the contacts in the pick up switch and or volume / tone controls have got dirty over time and are not making good contacts.
The 3 position toggle switches in most budget Les Paul copies are prone to failure - only making contact on one position as the springs get weaker - you could try unscrewing the back plate and examining what is happening in the switch.
Try rotating the volume and tone knobs vigourously to and fro - if this produces a crackling sound the contacts are dirty - further rotation will clean them a bit but a little squirt of switch cleaning spray will help too.
Other than that it could be dry solder joints anywhere on the back of the switches and knobs or poor contact inside the jack socket
Posted on Feb 27, 2011
What Epiphone model did I purchase?
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Feb 21, 2016 | Epiphone Music
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
How to lower the action on a les paul safely
The bridge should be on two posts, both of them with knurling on the edge. These screw into the body of the guitar, allowing you to raise or lower the action of the strings. Turn them clockwise to lower the action, making sure to turn them the same amount, so as to keep the strings even. You WILL have to re-adjust intonation after this.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 11, 2011 | Gibson Les Paul Studio Electric Guitar
Which knob does what on the epiphone les paul studio? there are 4 knobs and the only one i can figure out is volume.
I believe the top front is volume for the front/neck pickup...the top rear is for the rear/bridge pickup and the other two are tone knobs for the front and rear pickups.
Feb 10, 2010 | Epiphone Les Paul Studio Electric Guitar
Les paul making wierd noises
Unless you are wanting to use the Nanomag, I'd just get it taken out of the signal. You should be able to bypass it anyways.
Jun 05, 2009 | Epiphone Les Paul 100 Electric Guitar
Epiphone Black Beauty controls don't seem to work properly
The volume is a common problem ... Search for wiring diagrams for your guitar to find a better wiring. Or take it to a guitar repair centre to have it fixed.
To tell which pickups are selected with the switch if it doesn't have the little plate telling you, Turn one volume down and flick the switch one way so you can hear just one pickup.
Two ways of telling which one it is picking up ... A toppy tone is the one nearest the bridge ... a bassy tone is the neck pickup ... The middle selection on the switch is both coils selected ... If you cant tell by tone ... Tap the pick up and you'll soon hear which one you have selected.
Apr 18, 2009 | Epiphone Les Paul 100 Electric Guitar
Amplifier is buzzing when i plug in my les paul but ok with other
Several things to try:
- Probably already have, but another guitar cord.
- Ground switch on the amp?
- I had an older guitar that buzzed due to the pickups. While touching the strings, all was well - I was acting as the ground then. The ground wire broke, so it buzzed no matter what. The ground wire ran to the metal bridge.
- Play louder than the buzz! :)
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
Minimal to no bridge
Sounds like you have some microphonic pickups. Only thing to do is replace them. This would be caused by the guitar being hit against something or being dropped.
Feb 03, 2009 | Epiphone Les Paul 100 Electric Guitar
Low volume on front pickup of Epiphone Les Paul
i have an old sg, and this happened to me too. the repair guy told me that inside the p/u, the windings were broken, resulting in a lower output. go on e-bay, and look up a neck pos. humbucker. there everywhere. or do yourself a favor, and do what i did. i have an epi. flying v, and epi. les paul. on e-bay, i bought gibson 57 classics. i put these in both my guitars, and i now have great sounding guitars. you will not belive the difference. good luck, scott
Jan 31, 2009 | Epiphone Les Paul Studio Electric Guitar
Epiphone volume and tone controls
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
Oct 27, 2008 | Epiphone Music
Music Logo
111 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
