SOURCE: password forgotten nokia n73 memory card
hii
i have forgotten my N 73 memory card password pls help me out
SOURCE: I HAVE NOKIA 5610 AND I FORGET MY MEMORY CARD PASSWORD PLEASE TELL ME
hi, U actually didnt set it in the 1st place.
This is a recurring problem with Nokia handsets.
Please do not format your mmc just yet!
You can solve this by DE-ACTIVATING THE PIN CODE..
so go to Tools-->Security (if the 6233 is anything like the E50)..then deactiviate the pin code & any other security code you have on.
The next step is to SWITCH OFF YOUR PHONE.
Now SWITCH it ON again.
Yippee, you should now be able to access the content of your MMC.
i suggest you just make do with your unlock code or security code & not set the pin code.
If it ever requests the password again, then follow the procedure above.
I hope this helps:)
SOURCE: My Nokia 5610 music phone got password protected
If you have a Memory Card adapter slide the micro sd card into the adapter, and make sure the slider on the adapter is NOT in the lock position. If you do not have an adapter put the sd card in the phone and then go through all your memory settings and make sure you dont have it locked through the phone. Hope this helps!
SOURCE: i have a nokia 5610 phone, in which memory card
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: memory card not detected
try to backup the data from the card and then format the card.and clean the phone slot for memory cards with some alchohol.but be carefull.
