Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
Posted on Feb 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the digital optical audio cable connector on mode DAV-HDX267W?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Feb 27, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767728
Points
24828
I recently got a DAV-HDX576WF system. Everything works well but I dont get any sound from the left side when in TV mode, Im using a fiberoptic cable for the sound from my TV
Failure of a digital feed can't be channel-specific. The bitstream either works or it doesn't.
It sounds more like an analog audio feed with a failing channel cable. What path does the "TV" audio follow before it gets to that fibre optic cable?
I'd draw the sound from the Cable Box and bypass the TV.
Can the sony bravia home theater system be surround for both dvd and tv?
Strickly speaking about the audio:
The unit has digital audio in on 1 each coaxial and digital connectors.
Most DVD players have digital audio out in either a coaxial (RCA-looking) cable or optical cable.
Consider this: your TV is not a Source of audio (or even video, if you think about it). You probably get your programming from a cable or satellite box, Its audio should be available digitally.
If your DVD and cable use DIFFERENT types of digital audio sources, you're in luck. Attach each one to its compatible input on the Bravia. If you only have two optical outputs you can only attach one at a time.
If you have only two COAXIAL digital audio sources you CAN combine them into a single digital input on the Bravia by getting an RCA-splitter cable to connect them both to the one connector. It will only work if you leave one source dormant or off at any time you're monitoring the other source, otherwise you'll have two digital 'converstions' going on with the Bravia at the same time and it won't be pretty.
1helpful
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
1helpful
2answers
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
No sound when trying to connect PS3 to DAV-HDX275
It's likely the sound settings on one or more of your items are not set right or switched off.
1helpful
3answers
I cant hook my PS3 to the surround system for Sony DAV-HDX275W
what exactly is the problem? no connections? or connected and cannot get it to work?
2answers
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
1helpful
2answers
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
