Question about Health & Beauty
I would suggest you wash your little girl's hair with shampoo first and then use a really good conditioner, like Pantene Pro-V. Then with a wide toothed comb slowly comb out hair while it's still wet starting from the bottom of the hair and working your way up until you can comb through it all from top of head to bottom.
Shampoo and conditioner should be part of your daily hair care routine if you're prone to knots.
In addition, you can follow these few simple steps below;
1. Section off the area with the tangle. You can use hair clips if you wish, to do this.
2. With your left hand (right if you are left handed) wrap your hand around the section of hair.
3. Grasp and hold the section of hair tightly. You should not be 'pulling' on the hair. There should be a bit of 'slack' - leaving the hair from your hand to the scalp 'loose'. Holding this hand / hair in place will prevent 'pulling' of the hair from the scalp when you begin to comb through it.
4. Starting from about 1 inch from the tips of the hair, gently begin combing / brushing the hair toward the tips.
5. Once that area is clear of tangles, move up 1/2 inch to 1 inch at a time. With quick, fluid, and even strokes, comb through to the end with each pass.
6. Repeat as needed.
Good luck.
Posted on Feb 26, 2011
Jan 27, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Aug 06, 2013 | Health & Beauty
Apr 28, 2017 | Sew D'Lite Lightweight Portable Mechanical...
Feb 14, 2013 | Health & Beauty
Nov 23, 2010 | Health & Beauty
Jul 09, 2010 | Husqvarna Garden
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Apr 20, 2009 | iRobot Roomba 560 Robotic Vacuum
Feb 20, 2021 | The Health & Beauty
113 people viewed this question
Hi, Thank you for your reply and suggestions. We will give it a go and see how it goes; it sounds like very good advice.
This sounds like very good advice and we will certainly give it a go! Thank you!
