There is no point asking. If your spare part is also type 1 or type 3 compatible then who cares? In case you find a spare part that is only compatible to the type 3 machine and yours is type 1 then you should find the type 1 one because this is only compatible with your machine because that spare part is not a part of the type 1 machine.
SOURCE: Air Compressor
Dewalt recommends synthetic oil in their compressors. The dewlat part # 5130427-00 quart, and 5130702-00 for a 4oz size. Available at www.dewalt.com or their service center. I have been using the Lowes brand of synthetic compressor oil. Kobalt oil sells for about $7 and works great. If you do not use your compressor all day like I do, you can use the standard grade of Kobalt compressor oil that sells for around $3. Synthetic oil is for extreme conditions. Good Luck!
SOURCE: What is the difference between
When searching for a tool or machine part at eReplacementParts.com, the product's model number and type number are always necessary to ensure an accurate part match. Even when a model or type number is only different by one digit, the parts for that model or type may not be compatible with other models and types.
Each manufacturer uses a different model and type number system, and manufacturers often call type numbers by different names. Some type numbers are especially difficult to find on the tool or machine.
This article provides explanations and pictures for finding model numbers and type numbers for several tool and machine brands, making it easier to order the right part for the right tool.
Explanations are listed below alphabetically by brand, but first, some additional information about model numbers and type numbers will be helpful.
Model and Type Numbers
Model numbers distinguish a manufacturer's models for a certain kind of tool within a given tool category (like drill/drivers and nailers). For example, two different power sander designs from the same brand would be distinguished by having two different model numbers. This is true for every b rand, that they separate major designs by model number.
However, manufacturers often update the design or features of a tool model, creating types of tools with the same model numbers. Most manufacturers distinguish the different types of a tool model from one another by assigning type numbers to them in addition to the tool's model number.
This is where it gets tricky. Finding type numbers for tools can be difficult because of the following reasons:
In general, when searching eReplacementParts.com for the right model number and type number of a tool, the most important idea is just to match all numbers displayed on the webpage (under that tool's picture and name) with the numbers on the product.
On eReplacementParts.com, type numbers are displayed under the tool picture to the right of the model number. Sometimes type numbers are displayed in parentheses, like "(Type 1)" or "(0601916460)". Models that are not assigned type numbers will not have a type number displayed on the web page.
However, we will often list "Type 1" or "Type 0" for the first redesign of a tool model in a type series, even if the manufacturer does not list "Type 1" or "Type 0" on the name plate. This makes it easier for our customers and us to tell the first type apart from the rest.
SOURCE: It is an electric motor Dewalt Emglo Compressor
Dewalt recommends using synthetic pump oil, however if you only use the machine occasionally and not in a commercial setting, standard compressor oil will work great and save you money. Synthetic oil will last longer and can take much higher temperatures without breaking down. Lowes sell the kobalt brand of compressor oil and sells for about $3 for standard and $7 for synthetic. Home depot sells campbell hausfeld brand but equally as good. Auto parts stores also sell a line of compressor /pump oil just watch pricing for your needs. If you can't find compressor oil, non-detergent motor oil works just fine. Good holidays
SOURCE: Hey there. I am having
The cold start valve will close when volume of air from compressor is sufficient to overcome spring under pin (allows the motor to come up to speed). Evidently your compressor is producing very little air. Usually the problem is leaking or broken reed valves or gaskets. Remove the head and look for torn/ leaking gaskets and replace as needed. Examing the reed valves and seats and look for broken cracked reeds or worn seats. Some of the valve plates used in Dewalt compressors are made of aluminum and would fail. Parts are available at www.toolpartsdirect.com or local dewalt service center. Good luck with your repair.
