Remove the 3rd draw check for paper behind it ALSO REMOVE THE PAPER BEING STORED ON THE LEFT SIDE OF THE DRAW not a storage location it is use if you plan on placing 11x17 paper in the draw, if not above the motor is burned out and or worse case the main control board is bad, recommend you contact Konicaminolta dealership for the motor or the board if required
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: tiene codigo cf-033 la copiadora
you have two different models listed .Well for the Di 450 _CF033 error
Description:
C0F33.
Solution:
Check
to make sure that the ATDC value noted after running F8 was entered as
the "set" value in the Adjust Mode. If the ATDC "set" value was correct,
check the connections between the PWB-A and the ATDC.
To check the ATDC "set" value follow the procedure below:
1. Enter the Tech Rep. mode.
2. Press the stop key and then the start key
3. Select printer.
4.
Select ATDC reference value. The current value should be close to 5V
and the set value should be the same voltage setting as the current. If
the value is found to be at "0V" the ATDC setting was not set properly
when new developer was installed.
Note: When installing new
developer, make sure that the toner hopper and sub hopper are empty. If
not, extra toner may be added at the time the ATDC reference value is
set (during F8 process). This will cause light copies. please send more feed back on di 183 problem
SOURCE: que significa el codigo f2-02 de una copiadora
me marca codigo f2-02 copiadora sharp AR M455N
ke puedo hacer sera que es le chip o el cartucho.
SOURCE: en la minolta 2050 codigo c0fe8 que significa como
just check the developer maybe the developer is empty
