Question about Refrigerators
The ice maker on the kitchen aid refrigerator is not producing any ice.
Posted by cguntharp on
nothreat321
    New Friend:
  • 46 Answers
Check the cut-off/ overflow bar, its the little rod that lifts up as the tray fills. It normally does not become stuck but has a catch n hold position when moved up to a certain point. This allows you to stop ice flow and water from filling the ice maker tray for maintenance, cleaning and keeps ice from building up and getting stale and bad tasting. If you have an in line water filter or cut-off valve, these may need to be replaced and checked to see if they are functioning. Check the water supply line that runs from a source to the refrigerator to be sure it is not clogged, kinked or compressed. The ice tray may also have to be pushed "back" into the slot so that a safety/shutoff latch is triggered which controls the water/power to the ice-maker unit. A good idea to unplug fridge/freezer when checking water line connections and be sure to know where your main water supply shut-off valve is, this small supply line will put a gallon of water on your floor in less than 3 min! Good luck.
Posted on Feb 26, 2011
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
I have a kitchen aid fridge and my ice maker stop producing ice i tried turning off the ice maker switch for 30 seconds and on again waited 24 hours and nothing what else can i do to resolve this issue.
You can use this ice maker manual to trouble shoot and repair your ice maker.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f6bad9d0e44bf81d852573e900695d73/$FILE/8178689%20%28Icemaker%29.pdf
Jul 09, 2010 | Refrigerators
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Not making ice
The oil from the compressor has pumped up to the top part because of it only the ice maker s not workind change the lead valve of the compressor which can rectify your problem
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
