SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
SOURCE: electric range problem
Give me the brand and complete model # off the sticker on the range so I can help.
SOURCE: Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
SOURCE: replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
