Birdnesting is a common but very frustrating problem that can be resolved easily once you know where the problem originates. Remember, if the birdnesting occurs on the underside of the fabric, the problem originates with the upper thread. If it shows on the top of the fabric, the problem is the bobbin.
Very often, the machine is not threaded correctly. Remove all the thread from the machine. Check there are no loose threads or lint stuck anywhere in the machine. Oil as instructed in the manual.
Install a brand new needle! The needle should be suitable for the thread and fabric you are using.
All About Needles
ALWAYS RAISE the presser foot and rethread the upper thread. Verify the path is correct.
Check that the bobbin is installed and threaded properly.
Pull the bobbin thread to the top of the fabric.
How and Why to Bring up the Bobbin Thread
Set the upper tension to the midway point.
While holding both thread tails lightly in your left hand, begin sewing slowly.
sewing machine birdnesting Google Search
