Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Posted on Feb 26, 2011
WHAT IS THE INPUT VOLTAGE AND AMPS OF A 500 GB WD EXTERNAL HARD DRIVE. I LOST MY ADAPTER
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
6951
Points
58
You can normally buy a replacement adapter from Western Digital from this link, but they are out of stock at the moment.
http://www.wdc.com/en/products/products.aspx?id=240
As an alternative place to purchase this, it looks like you can buy it on Amazon.com
http://www.amazon.com/GEP-Adapter-Western-Digital-External/dp/B004IG548U
1helpful
000 wd5000c035
Yes, this model is certainly compatible with Windows 7.
If you've lost the AC adapter and need to replace it, the most important things to look at are:
1) the size of the plug
2) the input voltage of the drive
3) the minimum current in Amperes (A) or milliAmperes (mA) required
For units manufactured after June 1st 2008, these are the requirements:
12 Volts
1.5 Amps
18 Watts
Western Digital recommends only using original WD power adapters.
See here for more information: https://wdc.custhelp.com/app/answers/detail/a_id/1378/related/1/session/L2F2LzEvdGltZS8xMzg3MTQwNTQxL3NpZC9aNG1NbVZIbA%3D%3D
Tip: sometimes you can find a cheap and original power adapter on eBay or Craigslist or Kijiji.
I have WD My Book Essential 2 capacity 500 GB. Unfortunately everytime I connect it to the PC and power, does not show as a hard drive and has no driver. I backed up my files on it from the same computer...
you may have a bad drive,but first dose the drive power up not just light up can you hear the drive.
what you have in the box is just a nornal HD in an external box. you can if "absolutely nessesary " remove the HD and put it into your PC as a second drive.
but first you need to know if it is running and if the WD My Book power supple is working.
Have you tried using a different USB cable? a different power supply of the same Voltage & amps.
My WD My Book 500 GB is not recognized by the computer, gets hot and vibrates
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Whats the input and output for a a power adapter needed to work a wd elements 500gb external hard drive?
Check the label affixed on the unit. It should indicate the power requirements. If not, go to the Western Digital website and locate the specifications for this particular model.
What is the voltage for the adapter to power this unit
output is 12v and 2 amps, you can go higher in voltage and amps but i wouldn't go lower, it would cause the little motor inside to heat up
WHAT IS THE INPUT OF 500 GB MY BOOK ESSENTIAL EDITION?
AC INPUT VOLTAGE - 100-240VAC
AC INPUT FREQUENCY - 47-63 Hz
Input Voltage on WD MyBook and Elements
NO, they are not all multivoltage. Especially if you bough *** in the states as a 110v. You will need to have an external voltage adaptor in use.
3helpful
Power requirement to identify the right transformer among many
Output voltage is 12 volts at 2 amps. 24 watts.
See if it looks like this,
http://cgi.ebay.com/12V-AC-Power-Adapter-For-Seagate-FreeAgent-Pro-drives_W0QQitemZ260396021307QQcmdZViewItemQQimsxZ20090419?IMSfp=TL090419153008r30934
I can't locate my power adapter for my WD storage devivce
they all use 12V , so just get any 12v transformer that fits
the amp is i think 3.1amp or near.
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
