Question about Scubapro Full Face Mask, All
My Scubapro face mask leaks. I tried it first in the bathtub and then in the river. When I take a breath then put it on it stays for a while. I tried blowing out of it and the air was going out under the band on the left hand side. I bought this new and am very disappointed as I am going to Puerto Rico and will have to buy another.
Posted by bettyjanos on
1 Related Answer
Anonymous
SOURCE: how to use safe second with a Scubapro full face
where to get the Scubapro Full Face Mask Octopus Adapter Kit
in the usa
Posted on Apr 01, 2010
How to fix my air whirlpool leaks
If the light fixture is leaking you will need to remove light housing and put a small bead of silicone around the face flange and reinstall it.
Rod
US Parts Center
Feb 06, 2013 | Kohler K-1457-AH-96 Portrait 5.5 whirlpool...
Replacement Quick Disconnect Strap Buckles
You won't find any spare parts as Sherwood don't supply them.
Your mask had a limited 12 month warranty from new, so if it's under warranty still then Sherwood will likely either replace the entire mask or take the parts you need off a spares donor for you.
Click here to contact them.
If you can't claim under warranty they may still decide to help you on a goodwill basis, but in future if you want reliable spares and aftersales support buy established market leading brands such as Mares, ScubaPro, Cressi etc.
Mar 29, 2010 | Sherwood Oracle Mask
Leaking at glass connections at top of mask
I hope you don't think I'm being rude, but the best and most reliable fix is to chuck away the appalling bit of rubbish which U.S. Divers conned you into buying and replace the mask with one which is designed for divers by divers (snorkellers included!). This would mean almost anything by Seac Sub, Mares, ScubaPro, Suunto, Oceanic, TechniSub and others.
I'm sure that the "U.S." in the company name means "UnServiceable".
Light-heartedness aside, I am being serious. There are the overpriced but cheaply made and badly engineered items sold by U.S. Divers and then there are items which actually work reliably. Despite the immensely better quality of the better brands they usually have models which start at low prices.
Despite my obvious dislike of the brand you have, it's fair to say that your problem could just be due to age or misuse: the silicone rubber skirts on all masks shrink and harden with age and the harder plastics in the construction distort and may also shrink. The processes are accelerated if you tend to leave your mask out in the sun and if you just stuff your mask unboxed into a dive bag with loads of other gear or towels packed on top.
You can try popping off the frame which holds the glass in place and then reseating everything correctly before reassembling, but I'm confident that this will be as effective as trying to pick your nose whilst wearing boxing gloves.
Jan 20, 2010 | U.S. Divers Manta Ray LX Snorkeling Mask
I curently do concrete floor staining and use ''Kure & Seal'' which is a Xylene based solvent. I wear a 3M full face repirator and hope that its enough as it seems to block the heavy fume smell out. So...
If you read the enclosure that comes with the replacement filters, you'd see that there is a recommended replacement cycle based on hours of use , etc.
I tend to err on the side of "it's my health and more often is better for me" method of thinking. I also tend to go one better than the filter element for the application.
With that being said, I would change out my filters every 3-4 weeks, if you're not doing the staining on a daily basis. As to storage and cleaning, I remove the filters from my mask and store them in an airtight ziplock type bag when not being used.
I wipe the mask with a damp (water only) cloth daily and also keep it stored in a cloth bag to protect the mask from damage (scratches, knocks, etc.) since it gets pricey to have to buy a new one too often.
I would also suggest you might want to try the 3M Organic Vapor/ Acid Gas Cartridge 6003/07047 to see if it provides a better quality of air, when working with your "Kure & Seal" product since it is designed to protect the user against acid vapor, thus it should be better at eliminating fumes when used with your full-face mask.
And, yes, you are using the right filter and the full face mask is a good idea, as it protects your eyes, which don't respond well to Xylene and other nasty chemicals, that could get splashed in them. Work safe!
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | 3M Particulate Respirator Filter 5P71,...
How to use safe second with a Scubapro full face mask
Yu only need the octopus adapter kit to put on an octo and you can swap out should your primary reg **** out.
Feb 18, 2009 | Scubapro Full Face Mask, All
How to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
Scubapro Full Face Mask, All Logo
154 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
