Question about Royal Sovereign Electric Bill Counter RBC-1003BK
Send me error EA2 - Royal Sovereign Electric Bill Counter RBC-1003BK
Posted by Pedro Solano on
Anonymous
    New Friend:
EA2 means the machine counted 2 bills as one bill. Typically, you must remove the bills and put them all back on the hopper when this happens. If you get the EA2 error often, adjust the position of the bill thickness adjuster. This can be found at the top of the counter. Adjust it to the right (+) to loosen the tension, or to the left (-) to tighten it. Test both to see which solves your issue.
Posted on Feb 28, 2011
Masterbuilt ea2 error code
Same problem here. Any answers yet?
Washer want wash
Hi Lisa Cornett - Typically error code EAE indicates a sensing failure on the line safe relay. I suggest having the power company check the frequency and voltage of the incoming water. If correct, for error code E5C, the speed control board will need replacing by a professional. If correct for error codes EA1, EA2, etc then more than likely the main control board will need to be replaced.
No pulse from coil on ford falcon ea2. have changed the coil, and checked fuses and relays.
check your points and clean them while u are there, and make sure the button (the bit that spins) isnt damaged.
4helpful
3answers
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
2answers
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
1helpful
3answers
Phone keeps sending message
see if the message is in the drafts folder or the sent items if so delete phone will stop sending
Send error report
there is not necessary to send the error reports
Royal Sovereign Electric Bill Counter RBC-1003BK Logo
Top Royal Sovereign Office Equipment & Supplies Experts
Tom Chichester
Are you a Royal Sovereign Office Equipment and Supply Expert? Answer questions, earn points and help others
