Sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
SOURCE: light blinks 8 times
I'm 58 years old. Have had red lines forever. Tonight turned tv on and it faded to blue.Kept on shutting off Red led light flashed 8 times Read your info. Decided I had nothing to lose. I actually fixed it myself. Probably just a quick short time fix but I'm happy tonight. I guess I'll start looking for new TV. Don't know if I'll go with another Sony. I've this one for 5 years. Should last longer than that (I think)
SOURCE: my panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
SOURCE: my sharp 56 inch dlp tv does not turn on. The
the possible problem of your lcd tv is a defective capacito0r on the power supply assembly
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
