Question about Dell 924 All-in-One InkJet Printer
Is there any way without install disk that was lost to use 924 as fax. Prints fine but no fax
Posted by John Bilella Jr on
Anonymous
    New Friend:
My dell 924 use to work great now when i try to fax it will scan document but instead of going into fax mode it just prints the scanned document? anyone know what to do for this
Posted on Jun 21, 2011
Joe Fine
  • 628 Answers
Go to the Dell website and download the software for your printer.
Posted on Feb 26, 2011
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
I do not have the installation disk for the Dell AIO 924
Click here to open the drivers download page for your printer.
Chose the right windows version in the box on web page above.
After download is complete install drivers.
Start driver installation with printer USB unplugged.
Mar 05, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 all in one will not print magenta
run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 19, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 fax
Hi ,
The 924 printer which you have is not a standalone faxing printer, in order to send or receive the faxes the printer should be connected to the computer and the phoneline should be connected to the internal modem of the computer and you will be able to send the faxes by scanning the document from the printer, you will find a software called ALL IN ONE CENTER installed on your computer , open the All in one center and then click on FAX Now and you will be able to send a fax.
Mar 29, 2008 | Dell 924 All-in-One InkJet Printer
HELP
In lieu of a CD installer, you may want to try downloading it from the Dell website and thereafter install in your PC. The drivers for a Dell 924 printer is available here. Please be reminded that drivers are Operating System specific.
Hope this be of use/help to you. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Lexmark X1270 All-In-One InkJet Printer
Installation
You can download the disk info from the website!
Oct 09, 2007 | Dell 924 All-in-One InkJet Printer
Will Print, Won't Copy
Make sure the drivers have been loaded properly by uninstalling them and completely installing them again restarting the computer and printer several times.
Aug 01, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
STEVE
paulgbrandon
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
