Question about MPMan MP-F75 MP3 Player
My mpman sporty 3 turned off while I was listening music. I connected it to PC but nothing appears, please help. Thanks, Ilija.
Posted by loncarevicil on
4 Related Answers
Anonymous
  • 513 Answers
SOURCE: Help my MPMAN!!!
If you couldn't find the firmware, here's a link - http://www.mpmaneurope.com/download.aspx?file_id=205 If the reset procedure suggested in the manual doesn't work, try taking out the battery for a day or two, that should also reset it. try switching the battery with another one. If it starts up when you connect it to the power cable then the battery or power supply system is at fault. If you still have a warranty, use it, if not, think how much a repair is worth for you and consult the shop you bought it with, or a similar shop that sells these products. Good luck
Posted on Mar 02, 2006
Anonymous
  • 790 Answers
SOURCE: my mpman mp3 player not working
maybe you have loose connection! at the port connection! you can re solder it!
Posted on Oct 10, 2007
Anonymous
  • 319 Answers
SOURCE: MPMan F60 T12 Windows XP Drivers
Click here for the Driver
Please rate...thanks!
Posted on Jan 02, 2008
Anonymous
  • 54 Answers
SOURCE: mpman sd card not recognized
You will not be able to transfer the songs to your media card and then transfer it to your device..
you will need to transfer it directly to your device from the computer...if you want i can send you a link where you can obtain your device USB cable.
Let me know if you need additional help
Thank you
Computerrep
Posted on Mar 06, 2009
How do I download music onto my old mpman f70
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 23, 2012 | MPMan MP-F70 MP3 Player
I was listening with my mpman sporty3 and in a moment it blocked, i pushed the bottom behind where is write "reset" and after it was switch off, died. what i have to do?
Hi
1 First connect it with ur PC with the data cable provided along with it.
2 If it detects ur hardware device then ur device is ok no physical damage.
3 Reinstall the OS with the help of the CD provided along with this player
4 Read the manual carefully before installing the OS.
Please note that never format the MP3 player while installing the Os the manual caonatins step by step procedure to install the OS follow that only.
If you format the MP3 player then ur Mp3 player willl be permannetly damaged.
Regards
Vipin Kakkar
Jan 25, 2011 | MPMan MP-H150 (1.5 GB) MP3 Player
I have a netbook. and my laptop is called sylvania. i was wondering if you can help me out? i cant seem to download any music watch movies listen to music or play games because you seem to need a adobe...
Hi there!
Yes, it requires flash player like adobe flash player to be able to play games, watch movies online, listen to movies and others. Just go to the adobe flash player website http://www.adobe.com/software/flash/about/ and click install to install it directly or go to www.youtube.com and he will ask that it needs flash player. Adobe flash download icon will appear or link will appear and just click the download link and it will directly installed it to your computer. That all and your problem it solve. Enjoy watching movies or listen songs if you want.
I hope it helps you.
Jan 13, 2011 | Sylvania G-Netbook
It won't turn on
DO NOT RESET IT JUST CONNECT IT TO YOUR PC AND FORMAT IT BY CLICKING RIGHT ON THE REMOVABLE DISK DRIVE ICON AND CLICK ON FORMAT THEN PUT YOUR SONGS AGAIN BUT BY SCANNING THEM BY ANY ANTI VIRUS BECAUSE HANGING IS DONE BY VIRUS.
THANKS AND HAPPY NEW YEAR :)
Jan 03, 2010 | Philips GoGear HDD6330 MP3 Player
How do I download music onto my Psp 300?
Please try the following:
  1. Step 1 First, add connect your PSP with your computer using your USB, but you have to go to "settings" and click on "USB connection"
  2. Step 2 When your PSP is connected to your computer, a hard drive will appear [for example: hard drive (F:)]. That hard drive is for your PSP
  3. Step 3 Click on that hard drive and make a folder called "music"
  4. Step 4 Finally, open your folder full of musics and drag musics you like in the the "music" folder
  5. Step 5 Finally, when you disconnect your PSP with your computer, go to "Music" on your PSP and listen to your favorite songs!
Hope it helped.
Nov 22, 2009 | Sony PSP-3000 Black Console
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
Jan 09, 2008 | SanDisk Sansa m240 MP3 Player
Jan 02, 2008 | MPMan MP-F60 MP3 Player
My mpman mp3 player not working
Oct 10, 2007 | MPMan MP-F75 MP3 Player
Help my MPMAN!!!
Nov 27, 2005 | MPMan MP-F75 MP3 Player
MPMan MP-F75 MP3 Player Logo
Top MPMan Audio Players & Recorders Experts
Are you a MPMan Audio Player and Recorder Expert? Answer questions, earn points and help others
