Question about US Night Vision Ultra PVS-7B Goggles
My pvs7 wont stay on thay shut of after 30 seconds and then start to shut of ever few seconds
Posted by panickypete on
Richard Morris
    Master:
  • 577 Answers
Hello, have you or someone else pointed this night vision devise at bright lights, street lights, head lights. If so, maybe the damage has/hasn't alread been done. STOP. This PVS-7 goggles with ITT image tube with generation 2 or 2+ or possibly generation 3 tube. The devise is an American made unit, and the best in the world. Nobody can compete with the USA on NV. They sat the standards on Night Vision.
Have you replace the 6 volt battery? Get the goggle in a darken room then turn the switch on.
see if the 25mm plate will turn green and stay on. But first replace that battery.
Therefore, if this test works, then never and I mean never shine NV devises into bright lights, it will destroy them every time.
PS. send me another message and let see what happen. stewbison
Posted on Aug 07, 2011
Why when my wifes sled overheated @ idle, will only stay running 30 seconds,keeps shutting down,will keep starting up and the that process starts again, 30 seconds,shuts down
first of all you need to know the year make and model of the vehicle you're talking about and exactly what is the real problem is it overheating I will not stay running
If you need further help, reach me via phone at https://www.6ya.com/expert/james_9c1b039055413ffa
Mar 06, 2015 | Cars & Trucks
My lights stay on when i shut the door thay should only stay on for 25 seconds
Hi Rick. for me sound reasonable as when remove the key come on,is for allowing you to do your moves and on locking are coming off.
May 02, 2014 | 1998 Oldsmobile 88
My lights stay on when i shut the door thay should stay on for 25 seconds when pull my key out thay come on 1998 odls
if the light switch is set in the right position,the timer relay could out get a workshop manual to locate relay ,in the meamtime to save battery take the bulbs out
May 02, 2014 | Cars & Trucks
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Replaced steering column on 2000 grand cherokee with LKQ which had a key,it starts but shuts down in a few seconds
the skim module needs programed at a dealer,it tells the security moduel the key code,if thay dont match it wont run ,thay charge a pretty penny for this service
Jul 21, 2012 | 2000 Jeep Grand Cherokee
2001 chevy 1500 truck starts finethe first time we try it after 5 minutes truck wont start again we left it for about an hour and the ruck started perfectly fine then shuts off after 10 minutes the code...
is the gas gage brok. i don't have a book yet . i go up to auto zone .if thay cant tell me i look in there books if thay have the right one.p001.thay always tel ya 02 or map cencer.is their a circuit breaker on the fuel pump circuit.a fuel filter could do that .a catalytic converter cold do that will tern pier red after 5 minutes and will shut the car down thay take about 45minuts to cool down the carbide beads.
Jan 26, 2010 | Chevrolet 1500 Cars & Trucks
I start the iphone and the apple just stays and the loading icon comes...the phone wont turn off manualy but shuts off periodically and comes back on....can anyone help me with this?????
Turn iphone off. Power on holding power and home at same time for 10 seconds, then release power button but hold home for another 30 seconds. Screen will stay blank but should be in DFU recovery mode. Plug into iTunes and recover.
Nov 03, 2009 | Apple iPhone 3G
91 4x4 starts wont sta running more than a few seconds
maybe your mass air flow sensor on your airbox?
May 05, 2009 | 1990 Toyota Pickup
Remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Jan 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
US Night Vision Ultra PVS-7B Goggles Logo
306 people viewed this question
Top US Night Vision Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an US Night Vision Optic Expert? Answer questions, earn points and help others
