Hi, Look in TV menu for settings of screen. ( aspect setting) 4:3 , wide screen mode , Normal (full), Zoom mode. You want Normal (full) mode. Good luck.
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
You should be able to get to the menu with the front panel buttons. Otherwise, try unpluging for a minute, this may allow a reset. Please do not rate me if this is no help.
I had the same problem. It's the default setting on your HD cable box. You have to go under the cable box's "settings" and switch it from "Zoom 1" to "Normal." I found the solution on Samsung's webpage. Can't tell you how much that was driving me nuts.
