Casio G-Shock GW500A-1V Wrist Watch Logo
Posted on Feb 26, 2011
On my Casio G-shock GW500A, the time is off. i dont want it on 24time and its an hour ahead
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Mar 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
20417
Points
64
Sounds like you're set for the wrong time zone, and your 12h/24h setting is off.
To change time zone: Hold down the adjust button until it beeps. Your time zone will be flashing at the bottom of the display. Use the Time Memo and/or Receive buttons to change it to the correct time zone. Then... To change to 12H mode: Press adjust again. 12H or 24H will be flashing at the bottom. Use the receive button to cycle the mode. When it's what you want, press adjust once more.
1helpful
Can't seem to get the 24 hour format (Military Time) to function. Yes, I have even tried to find it in the manuel !! mike
Unfortunately I can not check out watch functionality by model number GW500A-1V. Follow this link and enter required number.Casio online manuals sometimes differ from those supplied with watches, so, download this one and follow instructions. See if it'll help. http://world.casio.com/wat/download/en/manual/
I have a wave ceptor casio 4774 watch - looks great etc. Only problem is that I work in middle east and it does not correct itself so I am having problems constantly resetting the time. The casio watch...
Nothing you can do. Where you work (middle east) there is no time signal radio station for your (radio controlled) wave ceptor watch.
You can read more here:
http://en.wikipedia.org/wiki/Casio_Wave_Ceptor
I dont know how to set it to 12 hour. for my Casio G-shock 1289 DW-6900CB
Press the "adjust button" until display flashes.By pressing "mode" button
go to 12/24h setting.Press the lower left button to switch between 12/24h.
When finished press the "adjust"button again.
I have a g-511 and i need to set the hand set back one hour!
Which do you have a g-511 or a g-shock gw500A-1V which iswhat you are posted under?
The GW500A-1V is an auto set model that will set itself back to EST at 2:00AM
However, if you want to do it manually its pretty much the same procedure forboth watches
First press the mode button (the Lower left one) until the hour and AM/PMindicator are flashing
Then press the set/reset button (lower right) to cycle through til its one hourearlier than when you started
When the time is where you want it, press the mode button again.
Hope this helps, if not re-post with more details about specific model andfunction you are trying to access.
4helpful
Reset time on casio g shock
Click on my profile and browse through my tips and tricks till you find link to all Casio watch manuals. Use that link and follow instructions. Rate me, please.
10helpful
2answers
How to turn off alarm on g-shock casio watch
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
12helpful
How to change from 24 hour to 12 hour on g shock
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
