Question about Canon MP610 Photo All-In-One Printer
My laptop has CanonMP610 installed but when I click on print, I get a message that the printer is not responding. The printer cable is plugged into the computer and the printer works on another laptop.
Posted by helenmaccalm on
Jeremy Moore
  • 1,940 Answers
  1. Unplug the Canon MP610.
  2. Click on the Start Menu, then Control Panel. Open the Printers, or Devices and Printers control panel. Find your Canon MP610 printer and Delete or Remove the device by Right Clicking on the device and selecting Delete or Remove.
  3. Restart the PC.
  4. When in Windows, plug your Canon MP610 in and wait for device installation to complete, or reinstall the CD drivers.
  5. Try printing a test page.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Feb 26, 2011
How to print black and white on canonmp610
To just print black & white.
You can go to printer preference.
Select print in grayscale.
Jan 01, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
How do I change the ip address of the Dell 1720 dn printer to work with my network?
Ok the following instructions will help you reset the ip address of your printer however you must use the origina driver cd to do this. Follow the instructions below if you have no print server involved with this network. If you do use a print server let me know ok?
Print and Check the Network Setup Page
  1. When the Ready/Data light is on solid, press and release Continue to print a menu settings page and a network setup page.
  2. Under the Standard Network Card heading on the network setup page, make sure Status is Connected.
If Status is Not Connected:
    • Make sure the Ethernet cable is firmly plugged into the back of the printer.
    • Plug the Ethernet cable into another wall outlet.
  1. Under the "TCP/IP" heading on the network setup page, make sure the IP address, netmask, and gateway are what you expected.
  2. Ping the printer and verify that it responds. For example, at a command prompt on a network computer, type ping followed by the new printer IP address (for example, 192.168.0.11):
ping xxx.xxx.xxx.xxx
If the printer is active on the network, you will receive a reply.
  1. If your printer doesn't respond, or if the IP address is not what you expected:
    1. Insert the Drivers and Utilities CD into your computer.
    1. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start® Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
    1. When the Drivers and Utilities CD screen appears, click Set IP Address Utility.
    2. Select your printer from the "Configure Print Servers" list, and then click TCP/IP Settings.
    3. Make the necessary changes, and then click OK.
    4. Click Close.
    5. Print and check the network setup page to verify your changes.
Install Printer Drivers for All Clients
  2. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start®Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
  1. When the Drivers and Utilities CD screen appears, click Network Installation - Install the printer for use on a network.
  2. Select Install printer on one or more remote computers, and then click Next.
  3. Enter your Administrator user name and password, and then click Add.
  4. Select the clients or servers, and then click Next.
  5. Select the network printer you would like to install, and then click Next. If you do not see your printer listed, click Update to refresh the list or click Add Printer to add a printer to the network.
  6. Select your printer from the list. If you would like to change the printer name listed, enter a new name in the Printer Name field.
  7. If you want other users on the network to access this printer, select Share this printer with other computers, and then enter a share name that users will easily identify.
  8. Click Next.
  9. Select the software and documentation you want to install, and then click Install.
  10. When the Congratulations! screen appears, print a test page to verify the software is installed correctly.
  11. Click Finish to exit.
Aug 09, 2010 | Dell 1720dn Laser Printer
Won't print, even when USB cable is plugged in
Do a BIOS update and than do a fresh installation of the printer.
Jul 10, 2010 | Lexmark X4650 InkJet Printer
The printer does not respond to print order. I get a message saying camera is connected, it is not.
The Camera Detected message is your PC detecting the scanner on the Printer - What happens when you try and print?
Also, try the following:
Remove the printer USB cable from your PC -> Restart your PC -> Log back onto your Profile -> Click on Start -> Control Panel -> Printers & Faxes -> Delete all printer entries -> Restart your PC -> Log back onto your profile -> Plug the printer USB cable into the back of your PC -> Go into Printers & Faxes -> Right Click on the Kodak 5100 AiO entry -> click "Set as Default" -> Now try to print.
Oct 13, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Dell 968 printer not responding message please help
try unplugging the printer and plugging it back in, also do you have the printer set as the default printer
Apr 26, 2009 | Microsoft Office Professional 2007 Full...
Printer is on, all cords connected, but when asked to print gives the message "Printer not responding."
disconnect the USB cable from the computer. Reboot the system, once the system has completed reboot, plug in the USB cable between the PC and printer. The system should sense the printer and install the printer. Go to the printer folder in the control panel (START). You should see your printer. Select the printer, Double-click, Select File, Select Properties, Select Maintenance, Print Test Page.
This should clear the problem.
Apr 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Try the HP500Hpgl2 driver, it will work with a USB port.
Dec 13, 2008 | HP DesignJet 450c InkJet Printer
Printer won't respond
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Jun 29, 2008 | Epson Stylus C62 InkJet Printer
Canon MP610 Photo All-In-One Printer Logo
127 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
