Dryers Logo
Posted on Feb 26, 2011
My mothers 800 Series drier shuts off after running for about 10 minutes. After it cools down it can be restarted, then shuts down again. It has two temperature sd swtiches on the air exhaust. Could one of these be bad causing the shutdown?
Rod MacNeil
Level 1:
  • Contributor 25 Answers
  • Posted on Feb 26, 2011
Rod MacNeil
Contributor
Level 1:
Answers
25
Questions
0
Helped
14002
Points
48
There are temp sensers to shut the element off to control the temperature(could be overheating) as well as temp senser to shut it off if it overheats either one could be bad.
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Kenmore king size capacity 90 series
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Dryer runs for 10 mins and shuts off.
Your dryer motor has a thermal overload built in to it. If your symptom is shutting down allow to cool and it works again for a few minutes the shuts down again.
http://www.on-timeappliance.com/dryerrepair.html
1helpful
Kenmore series 90 washer runs for a short period and then stops
Sorry to be the bearer of bad news but what your describing is a classis sign of a bad motor. When the motor is bad it will run will its cool...when it heats up it shuts off and will restart for a short time when colled off till once again hot and shuts off again.
GENE
1helpful
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
87 Ford Taurus 3L engine shut down when warm - will not restart
after it has shut down check for gas at the fuel rail with the key on their should be gas squirting out constantly it sounds like the fuel pump is going out
1helpful
My Panasonic TU-PT700U Digital media Receiver shuts the TV down after 10-30 minutes and the blue light flashes 5 times repeatedly. I have to unplug the unit and let it cool for several hours before it it...
Hi, I have a spare TU-PT700U that may be of use for you to solve your problem without having to replace your system.  My Panasonic onyx series monitor was stolen out of my house, but they left behind the TU-PT700U and cable.   If interested, respond to my craigslist post..
http://sfbay.craigslist.org/sby/ele/930283631.html
2helpful
Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Kenmor dryer Series 80 110 668 14690
based from your story, you are tiggering a thermal overheat protection device. as the device heats up, it would trip off the dryer, and comes back on again after a few minutes but as the heat increases, the device is being triggered faster until the device would no longer trips back because the dyer is so hot that it would take about 10 mins to cool down. i think this is just a secondary problem, your primary problem could be lack of air passing through the heating element. please check the stroller blade for dirt of flint and debri, check also the outlet duct, it could be clogged with flint also. i hope i was able to solve your problem.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
