Question about Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor
K-9 MUNDIAL OMEGA R&D #432 How to turn on
K-9 MUNDIAL OMEGA R&D #432 How to turn on valay mode Tried holding unlock and aper buttom for 5 seconds/ten seconds
Posted by ovbj4 on
1 Related Answer
iadame
Israel Adame
  • 676 Answers
SOURCE: only one of my my k-9 mundial keyless work the
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Posted on Mar 04, 2010
Omega double wall oven model E88 stuck in demo mode and won't disable
Suggest you contact the manufacturer. There is little information on the web
Aug 04, 2016 | Ovens
Tip
Region Code
I was very mad because I looked for this code for long time over the web and nowbody know the unlock code for this pleyer but siting in front of it and thinking in all the posibilities i found it.Now I would like to sher it because for me should be no region codes for any player.
All you have to do it's :
1.-Make sure ther are no disc on the tray.
2.-Turn the pleyer on.
3.-Press the select buttom located at the front of the pleyer for about 10 sec.
The number of the current region will aper for example (1)
4.-then using the volume control (located olso at front of pleyer) change that number to (0) to make it region free .
5.- Do noting wait about 3 sec. and your player will be region free.
6.-Enjoy the show.
on Feb 29, 2008 | RCA RTD155 System
My 2002 Ford F-150 will crank but not start in theft mode no data link connection to pcm however computer has power to it but no power to pats system how do I fix?
Shut the truck then put the key in the door turn it right for ten seconds and hold it after ten seconds turn it left an hold ten seconds then unlock the truck and try to start agin this will reset the theft system
Apr 23, 2016 | 2002 Ford F-150
How to turn kill switch off and see manual and instructions
I am assuming that you want to disable the system temporarily by putting it in valet mode. You will need to locate the valet button; they are usually installed under the dash within reach of the driver. The button should be black and about 1/2" in diameter.
Pressing and holding the button for 3 seconds while the alarm is disarmed will put the system into valet mode. The system will turn the LED light on steady and chirp the siren to indicate that valet mode has been activated. To exit valet mode, press and release the button. The LED will turn off and the siren will chirp to indicate that you have exited valet mode.
The included link is for the manual, see page 8.
http://www.caralarm.com/manuals/K-9/K9-Mundial-ss.pdf
Nov 03, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
How to get rid of osd lock which appears frequently on screen?
Hold the MENU button for ten seconds to unlock or lock the OSD.
This information is from your manual for the L194WT:
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 08, 2010 | ViewSonic Computers & Internet
1999 Chevy silverado z71trying to program a new key fob
Use this procedure for New Body Style.
1. Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down
until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by
door locks locking and unlocking automatically. (If locks do not cycle after you let go,
not before you let go of the unlock button, then the vehicle has not entered programming
mode and you must start procedure over. Remove key from ignition, open drivers door
and return to step 1 ). If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and
unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
Apr 29, 2010 | 1999 Chevrolet Silverado 1500
How do i program a keyless remote for a chevy 2002 S10?
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
Mar 05, 2010 | 2002 Chevrolet S-10
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Can't get Blazer into transmitter programming mode
1. Close all doors
13. Test remote(s).
Feb 19, 2010 | 2001 Chevrolet Blazer
Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor Logo
1,076 people viewed this question
Top Dual Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Dual Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
