Sony DAV-FR10W System Logo
Question about Sony DAV-FR10W System
Getting a loud hum only from video function.
Posted by jshaw239 on
Robert
  • 176 Answers
Check your connections. Chances are you may have crossed the RED video cable and the RED audio cable.
Posted on Feb 26, 2011
Loud hum in my ge rc7200
More than likely the Magnetron is bad, causing the transformer to over heat. Or it could just be the transformer going bad. Either way not a good situation. Both are expensive.
Technics SL1210 mk2 loud hum, it's not the rca or grounding cable...
This normally happens when the carts are removed and the amp is up. Its called microphonic-ing. Cheers john. Styluscity.
Both Technics SL1210 mkII's loud hum and almost no sound...
You seem to have some feedback hum from somewhere. I would think it might be caused by a faulty connection somewhere.
2helpful
2answers
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Can I connect my Dual turntable to pioneer VSX D712 receiver. I tried connecting it to a preamp (bought from Circuit City) and then to AUX, but all I get is a loud hum
I presume you bought a PHONO preamp from RS. That should be all you need. Is the TT otherwise functional? Loud hum is usually an ungrounded or unshielded signal cable. Phone cartridges create such a small primary signal that any external airborne electrical noise entering the circuit will be very large in comparison. Check cables and make sure the headshell is locked in correctly on the tonearm. Examine the small cables connecting the cartridge. Dual = good turntables. I have a CS1249 from the 70's.
3helpful
2answers
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
2answers
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
Humming noise while recording
bad mic assy was the unit dropped ? possible bad ribbon cable or unit stored with battery still attached to unit.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
