Computers & Internet Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The print spooler is not working on my dell inspiron 530. I have tried to start it, but it will not start. Help!!!!!
Anonymous
Level 3:
Master:
  • Master 389 Answers
  • Posted on Feb 25, 2011
Anonymous
Master
Level 3:
Master:
Answers
389
Questions
0
Helped
83590
Points
1177
Have you gone to start, settings printers and faxes, right click on the printer in question, click on the advanced tab and click next to "spool document so it prints faster"? You will need to do this on the computer connected to the printer. Computers that are connected thru a network won't be able to make this change.
Let me know if this information is helpful.
Brian
When i start my dell inspiron 530 desktop....
according to dell's documentation, 2 short beeps means a memory problem. try the suggested remedy in their site.
don't forget to rate me if I was able to help out. :)
I have a inpiron 530 with a Photo 926 printer. It will only print the last page of a print job.
Hello randy,
This is going to take some troubleshooting.
Please try the following, and test after each change. Hopefully we can get this working for you quickly Verify that when you hit print it under print range that only the last page is selected.
Try printing a different document, this is assuming you've been only having the issue with one document. Try printing a different type of document, using a different program such as word, notepad, or even a multi-page website.
If any of these has worked for you then it has either narrowed it down to the specific document, or the program, re install the program in question.
If none of the following has helped.
go to start/run type cmd to open the command prompt type following net stop spooler net start spooler this will restart the print spooler service.
If none of the above worked, delete the printer and reinstall. If problem persists install printer on a separate computer to verify that it works correctly.
Good luck, and I hope i was helpful.
2helpful
Print Screen button on dell inspiron 530 dose not work? Nothing happens when trying is use Print Screen Button on keyboard. I am trying to save items in current screen to a file.
do u know how to use that button?
first of alll, decide which screen you want, press button and then open paint program and then paste it here, you will see that screen on your pain program, or you can paste that in ms word also. then you know what to do, right?
Printer spooler keeps stopping
I would like to know the PC Operating System, is it XP or Vista ?
If this is XP there is a Print Spooler Reset which you can try
Uninstalling Printer s/w may not help here
On this website you will find the FIXIT - download and run the Fixit
http://support.microsoft.com/kb/324757
Follow the instructions and click on RESET PRINT SPOOLER and continue till it prompts you to restart the PC
Once the PC is restarted and you see the Desktop - Disconnect the Printer USB Cable from Printer or PC and connect it back. it will install the Printer Drivers or prompt you to insert the disk to install..
you will be able to print without problems.
1helpful
Cannot Print from Dell 530 Inspiron w/Home Vista
Try this:
http://www.fixya.com/support/r3680773-completely_remove_printer_drivers
4helpful
2answers
Won't print Dell V305
It seems to be an issue with the Print Spooler Service. Either the service is stopped or not started correctly. Try stopping and restarting the printer spooler services on your computer. For tips on how to restart the Print Spooler service, use the link: http://www.ehow.com/how_2319117_restart-print-spooler-xp.html. Now Reboot your system and try deleting the print queue. It should work fine now.
Good Luck!
-Abhishek
Dell 720 printer won't print.
The problem could be because of ONE out of FOUR problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
2answers
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Dell Inspirion 530 won't communicate with Dell V305 printer
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Spooler problems
check Owners/Users Manual it should be there if not try win help
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
