Question about HP LASERJET P1006 Printer
My HP LaserJet P1006 says it has a paper jam. I have cleared all the paper that was in the tray - how do you open up the back? How do you clear a paper jam?
Posted by treetucker on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Unplug and power off the printer and wait 30 seconds. It will reset the device.
Posted on May 31, 2019
5 Related Answers
SOURCE: HOW TO CLEAR PAPER JAM HP LASERJET 3055?
please you see your copier paper feed sensor is open or delivery sensor is open or broken
Posted on Jun 28, 2009
Anonymous
  • 102 Answers
SOURCE: HP LaserJet P2014 keeps showing paper jam when
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
Anonymous
SOURCE: Cant figure out how to open Tray 1 to clear paper jam
Leave Tray1 closed. Remove tray 2. Push down on green arrows visible after removing Tray 2. You should see the jammed paper on the plastic tray which becomes accessible after pushing down on the green arrows.
Posted on Jul 17, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
Anonymous
SOURCE: HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Posted on Jul 17, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp laserjet 1005 printer second page paper jam
Hi senthil, my name is Lisa and I would be happy to help you with your Laserjet 1005. I understand you are experiencing a paper jam when printing multiple page documents.
There are multiple variations of the 1005, below I will list 3 links one for each of the 1005 Laserjet printers I think you could have.
Clearing Paper Jam for HP LaserJet P1005 P1006 P1007 P1008 and P1009...
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=1839458&docId=emr_na-c00765431&docLocale=en_US < HP LaserJet M1005 MFP - Clearing jams
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=bpl10965 < HP LaserJet 1000 Product Family - Clearing Printer Media Jams
I hope that one of these links is specific to your printer, and that the appropriate link helps you resolve the issue.
Best of luck. I work on behalf of HP.
Jul 02, 2015 | HP Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
Error light orange
This state can be reached in the following circumstances:
  • Paper tray is empty
  • Door open
  • Paper jam
  • Misfeed from tray
Action
Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
Verify that media is present in the input tray.
Clear any jams and perform paper-path functional checks.
To reset the printer after a jam, press the Go button.
You might need to clear the error manually, and press the Go button or close the top cover.
Nov 18, 2013 | HP LaserJet 1160 Printer
1020 hp printer problems
I would advise also opening the door on the back of the printer (if this printer has one), removing any paper trays and cartridges too. All of these can obscure places where paper can jam. Be thorough as even the tiniest scrap can cover a vital sensor.
Sep 06, 2012 | HP LaserJet 1020 Printer
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
The paper jamed now I get a 41.3 error message and can't solve
The error 41.3 is unexpected paper length and was caused by the printer pulling more than one sheet. Now the problem is clearing the paper jam in the paper tray. The only way I have found to get it clear is to put the printer on its back with the paper tray facing straight up. Now push the tray in just a little bit if you can and try to shake it to get the paper to shift to the other end. After a minute or two put the printer back down and try to open the tray. If you can then just put the paper back where it goes in the tray. Be sure the pickup roller is clean, no paper dust and such. then try printing again. If you still can't get the tray out then you will have to dis-assembly the printer to get it clearer. Let me know if this gets you going.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 19, 2009 | HP LaserJet 4 plus Printer
May 05, 2009 | HP laserjet Cp2025dn color Card Printer
HP LASERJET P1006 Printer Logo
660 people viewed this question
Ekse
efs_perpends
efs_perpends
