Proview PA-32JK1A 32 in. LCD Television Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I use my cable company remote for everything but tirning tv on off and volume.I hit a button on the tv remote,channel up I think,and have nothing on the screen but blue.How do i fix this?
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 126 Answers
  • Posted on Feb 25, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
126
Questions
Helped
22983
Points
371
Sounds like the input has been changed - if you dont have the original remote - find the input button on your tv and press it until you get back to your input that the cable is going in to .
Thanks,
Michael
6helpful
How to put in video mode without remote
press the menu button and you should have a screen with Picture,channel set,eng/esp/fra, V-chip set up, caption (off).
With picture being highlighted press the volume up button, then press the channel down button until you see game mode, then press volume up for on and volume down for off...
2answers
Hi, i was trying to turn down the volume on my tv (its an insignia) and i accidentally hit the channel button and i think it messed up the programming of my tv to my cable box. what should i do?
try setting the tv to channel 3 or 4. if that does not work, try finding a "input" or "source" or video" button on the remote and cycle thru them, this should get you back up and running. remember to have the cable box turned on during this so youll see when it comes back on.
3answers
I have two remotes. One to turn on the cable box and one to control the TV on/off and volume. When I was watching TV I hit the wrong bottom for the volume and now my TV is just noise and so picture. Can...
If the cable from the cable box is attached to the TV via a coax cable, then all you need to change the TV channel to either Channel 3 or Channel 4. You may have accidentally push the CH button on the TV remote. Please post back what you find.
19helpful
6answers
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
1helpful
3answers
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Sony tv channel display
You need a Sony remote that has a "display" button on it. Press the display button and it will go away.
TV Stuck on Video
hit input button u dont have orgibnal remote for tv so go to the tv hit ch down button to u see it chage the inputs to video 2 3 whatever your cable is on dvd ect ok
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Top Proview Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
