HP OfficeJet 6110 All-In-One InkJet Printer Logo
Anonymous Posted on Feb 25, 2011
My hp printer 6110 officejet all in one keep giving message scanner failure when i want to print something
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Feb 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
9465
Points
85
Please make sure that the printer is connected to a wall outlet and not to a surge protector because surge protector distributes the total electric supply equally to each and every device connected to that surge protector. Printer might work and might not with a surge protector but it will always work fine with a wall outlet till the hardware of the printer and power chord, adapter are working fine.
some times scanner failure error comes if it is not getting enough power supply.So if it is connected to a surge protector then I will suggest you to disconnect it and connect it directly to a wall outlet.
Now scan or copy any document and see if something happens.
If not the do check while you press scan or copy button the scanner light is moving or not?
If scanner light is not moving then do a hard re-set.
Hard Re-Set :
- disconnect power chord from the back of the printer and then from wall outlet or surge protector.
- wait for 40 secondsand then connect the power adapter to wall outlet and then to the back of the printer. The try to scan or copy....still not working then check if the scanner bulb is glowing or not?
If scanner bulb is not glowing and if you dont hear any noise while you press scan or copy...then printer hardware has gone bad and you need to replace the printer
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
3helpful
HP office jet 6110 all-in-one Scanner Failure message cannot be erased. When power is switched off/on makes load grating noise and Scanner Failure message reappears. Copier function will not work either.
Print head sticking needs oil on shaft that its slides on. Open cover and put a drop of oil on each side print head Shaft cut it back on and see if this helps .may half to do this 2 or 3 times to get the oil on to bearings . They dry out over time. Good luck
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
HP C6180 Scanner Failure error message
You need new scanner section but try first to clean this one.Disassembly the printer and pull out the scanner section.Open it cover and inside you'll see the mirrors.Clean the ash from mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
1helpful
2answers
Scanner Failure message on my HP 6110
have you tried plugging into a wall socket, sometimes using power supply or powerstrip or surge procter will not let enough elect through to the unit.
Hp officejet 6110 all-in-one
maybe you could try to reinstall the driver?
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
1helpful
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
k24674
Grand Canyon Tech
Grand Canyon Tech
