Question about Konica Minolta bizhub C250 All-In-One Laser Printer
We also have a Konica Minolta all in one unit but do not have an "administrator setting" after selecting the Utility/Counter button. What are other options to accessing report settings?
Can Guru
    New Friend:
  • 30 Answers
The Administrator setting will be available by entering the administrator password (8 dig-
its) The administrator password is initially set to "12345678."
Posted on Mar 06, 2011
Please how can I clear the memory on my printer (Konica Minolta bizhub C203 coloured printer)
Go to service mode
utility-counter-stop-00-stop01
go to system 2/ or 1
select initialization.
select all data.
press start button
restart from main power.
Re-configure all network setting for printing/scanning
Nov 29, 2016 | Konica Minolta Bizhub c203 Copier
Ihave konica minolta bizhub 43 i replaced anew fuser unit but its still showing consumable error replace fuser unit how can i solve this
Enter in the service mode: press Utility key-Metercount-(Details if exist)-Stop -0 0 -Stop -0 1 select a special parts life or in the counter mode consumable and reset the fusing unit counter.
Feb 04, 2013 | Konica Minolta Office Equipment & Supplies
Administrator log in
1-Press "Utility/Counter button from control panel.
2-Press "Administrator settings" from Touch screen LCD menu,
3-Enter "Admin Password" which is 12345678.
4-After entering the above password, press "ENTER" or "END" button, (appeared on top right side of menu).
5-After pressing the end or enter button you will be in administrator mode.
Now, if you are asking about the Administrator password, then the password is "12345678" This is the default administrator password of Konica Minolta bizhub MFPs and Photocopiers.
For any other queries, feel free to ask any time.
Jan 31, 2013 | Konica Minolta Bizhub C300 All-In-One...
Tengo una konica minolta di183f que me pide
Press the following keys in this order to enter the service mode:
UTILITY,STOP(red button),0,0,STOP,0,1.Enter in COUNTER menu,select maintenance counter,select the setting value using the Left or Right key.Press the Yes key.When 1 or 2 is selected for the setting value,the count value entry screen automatically appears.Type the count value from the 10-key pad.Press the Yes key.
Setting value = 0 - meaning NO COUNT it is default value.
Setting value = 1 Meaning - PERMITS COPYING - Display "M1".
Setting value = 2 Meaning - INHIBITS COPYING - display "CALL SERVICE(M1)
Aug 18, 2012 | Office Equipment & Supplies
How do I find and reset the IP address on a Konica C351
Utility/Counter button, Administrator, 12345678 or 00000000 is password
select network setting. You can make changes to IP, DNS, Gateway, Subnet, SMTP , ect.
Apr 16, 2010 | Konica Minolta bizhub C351 All-In-One...
I have a konica bizhub c351, I have changed my network here at the office. This IP address is 192.168.15.50 and now I need to change it to 192.168.0.50. Can you help me?
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Nov 25, 2009 | Konica Minolta bizhub C351 All-In-One...
I used to be able to scan to email from my konica Minolta 252 biz hub. I now get a 'server connect error' and cant send to e mail. how do i resolve this? thanks, Steve
the email server address may have changed
touch the utility counter button the the administrator button
touch network setting
touch email setting
touch fwd button
check to see if the host address is correct for email server
or check the email one touch button settings
To edit a one-touch E-mail address:
1. Press utility/counter.
2. One touch user box registration.
3. Create one-touch destination.
4. Address book.
5. Email.
6. Select the E-mail address.
7. Edit.
8. Then edit the address
Sep 28, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
How can I set up passwords on our bizhub? We do not want students to use it.
That would be under the USER AUTHENTICATION/ACCOUNT TRACK section of the Administrator menu. This set-up is slightly different on some models, but start with the Utility/Counter button and then the Administrator menu.
Sep 24, 2009 | Konica Minolta Office Equipment & Supplies
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Oct 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
145 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
