Washing Machines Logo
Question about Indesit W 83
My washing machine Indesit W1A121 has starting make an awful noise on the long spin. Allowing for the cycle to finish to be able to open the door, I think the drum is moveable/loose more so than normal. What could this be and is it something I could fix myself? Please advise. Many thanks.
Posted by sharonlepage on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Indesit W123s
Bearing Kits are available from here: http://www.ransomspares.co.uk/indesit-washing-machine-spares.html You need part number 1605077
Posted on Feb 28, 2007
Anonymous
  • 66 Answers
SOURCE: indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
Posted on Jun 15, 2008
Anonymous
SOURCE: Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Posted on Jul 15, 2008
Anonymous
  • 333 Answers
SOURCE: Door of indesit washing machine no opening model no WM12X
First thing if this unit has an electric lock you probably open the door at the wrong time and threw it out of sync. First try to do another load from the beginning cycle and let it finish. If this don't work unplug your machine and then try. I hope this helps you.
Posted on Nov 23, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Posted on Dec 22, 2008
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Door not locking nor spin cycle not working
Hi.
Before proceeding to spin the timer does a check on the lid switch.
You should be able to fix the problem replacing the lid switch.
Regards.
Ginko.
1helpful
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
2helpful
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Indesit wil 103 door won't open...
Welcome to Fixya.
It does not open
turn the machine off at the mains, after two minutes the door should release from the auto lock, but your pcb (printed circuit board) is knackered start saving.
Top Indesit Washing Machines Experts
Marvin
Marvin
sheakhly
Level 1 Expert
mark warfield
mark warfield
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
