Question about Samsung HMX-E10 Camcorder
My Samsung HMX-E10BP/EDC is stuck in DSP Tester mode. It says press menu for config, But that does nothing. It also displays a "wait HDMI connection" message but all that happens is that it displays the camera view on my tv. any assistance with this problem would be greatly appreciated. thank you.
Posted by a_zrael_uk on
W.L.
  • 2,509 Answers
Try removing the battery to reset it. SAlso check that none of the buttons are sticking.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 25, 2011
Penegin
    New Friend:
I found a solution:
Remove the back cover and the battery.
Carefully open the camcorder by removing 7 screws. You'll see the logic board.
Remove the screws holding the logic board (my camcorder had only one).
Carefully disconnect the 2 bottom flex cables (you don't need to remove the others).
Look at the opposite side of the logic board and find a tiny button cell. You just have to carefully remove it, and then place it back. There's a high risk of breaking its housing clips, but don't worry, it's not a big deal. If you break them, your camcorder will still work. It'll reset its settings every time you remove the battery (or fully discharge it), but it's still fully usable.
Posted on Oct 26, 2014
darzuadrian
    New Friend:
I also have a problem. my cam corder, same model is stuck in testing mode " LEST TEST: AF MOVE ...)
test cound (1)
what can i do to get rid of that? pls help
Posted on Jan 12, 2013
  • darzuadrian
    darzuadrian Jan 12, 2013
    i also have a problem. my cam corder, same model is stuck in testing mode " LEST TEST: AF MOVE ...)
    test cound (1)
I can't view my photos and videos in my camcoder
Can you view them through the computer by downloading them? If so your view screen is defective.
Oct 14, 2016 | Samsung HMX F90 HD Camcorder, 5 Megapixel,...
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
Tip
HORIZON FITNESS TREADMILL ENGINEERING MODE AND RUNNING BELT ADJUSTMENT
Eng0 - Display and Button Check
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng0 appears in the display.
2. Press "Enter" to select Eng0.
3. Press "Start" button to verify all LED's
Eng1- Hardware Test
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng1 appears in the display.
2. Press "Enter" to select Eng1.
3. Press "Start" button to verify belt movement, sensor wire, and elevation function.
Eng2 - Auto Calibration
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng2 appears in the display.
For more check the following link . from the drop down menu select treadmills.
on May 03, 2015 | Horizon Exercise & Fitness
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
It keeps saying "menu disable"
Please try to do the following steps to enable menu
1 Turn the printer off.
2 Press and hold Select and Return and turn the printer on.
3 Release the buttons when you see Performing Self Test.
Config Menu appears on the first line of the display.
4 Press Menu until you see Panel Menus, and then press Select.
Enable appears on the display and press Select.
5 Locking Menus appears briefly.
6 Press Menu until you see Exit Config Menus, and then press Select.
Sep 12, 2011 | Lexmark T630 Laser Printer
Main Motor Error message on a Samsung color laser printer CLP510
Hello Don,
One other fix you can try is accessing the hidden maintenance mode. Try this;
You can enter the menu in this way:
Start up the machine with push in the buttons "online" and "cancel"
--You will see the message "Download mode press online key"
Press about 15 times the "menu" key
--You will see the message "Uncheck consumable mode"
Press about 15 times "menu" and 5 times "enter"
--You will see "Press access key"
Press a few enters
Press 3 times "cancel"
Go to the EDC mode
-- you will see "press access key"
Press "cancel"
Go to maintenance and initialize the parts you like to reset.
Dec 01, 2008 | Samsung CLP-510 Laser Printer
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Nov 30, 2008 | Onkyo Audio Players & Recorders
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Samsung CLP 510 laser printer
Try this:
There is a hidden maintenance menu in the machine!!!
Press a few enters
Go to the EDC mode
Press "cancel"
Nice isn't it?
(sometimes you have to try a few times; don't wait to long in between the steps)
Jun 05, 2008 | Samsung CLP-510 Laser Printer
Samsung HMX-E10 Camcorder Logo
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
