SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: panasonic hd tv light blinks 7 times
Unfortunately this appears to be a common issue developing with these Panasonic sets i.e the '7 blinks of death'!
Several customers are complaining about it. The problem is caused by one, both, or all of the following boards: SC board, SD board, and SU board.
Most commonly, the SC board is the one that has failed and because Panasonic have received so many complaints about this issue they are now agreeing to replace the SC board under extended warranty.
However this is not widely known amongst the general public and Panasonic have kept it very quiet.
I would suggest that you make contact with the Panasonic Concierge service centre. Make them aware that you are aware of the SC board issue and that there is an extended warranty on this and ask them to replace it.
However if it happens that one of the other boards has failed be aware that Panasonic are not covering these under warranty and you will be charged for the repair in this case.
The Panasonic Concierge service is available from here
Thanks for using FixYa.
