The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Posted on Feb 25, 2011
Feb 10, 2014 | LG 65 Pint Dehumidifier Auto Shut-off...
Nov 13, 2013 | LG LD450EAL 45 Pint Dehumidifier
Aug 22, 2011 | LG LHD659EBL Dehumidifier
Aug 13, 2011 | LG LHD65EBL Dehumidifier
Jun 28, 2011 | LG LHD45EL Dehumidifier
Apr 14, 2011 | LG LHD659EBL Dehumidifier
Mar 31, 2011 | Comfort-Aire BHD-651 Dehumidifier
Mar 01, 2011 | LG LHD45EL Dehumidifier
Feb 15, 2011 | LG LHD65EBL Dehumidifier
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
Problem It shows Bucket Full
heatman101
Jan 24, 2011 | LG LHD45EL Dehumidifier
756 people viewed this question
